Oh what a feeling
Drives: Yaris Join Date: Sep 2011
This probably only applies to stick shift Yaris...
I notice that when I turn the A/C on, the idle RPM goes up a little bit, and the throttle is much more responsive from idle than with the A/C off. I sometimes inadvertantly stall the engine, usually when I'm not using the A/C. All my other cars have idle at 800. Did Toyota set it at 600 for some reason? Like emission? Will my car fail emission test if I increase the idle to 800? Will CEL come on? |
![]() Drives: toyota vitz 06 Join Date: Oct 2012
HI I HAV A 2006 VITZ HATCHBACK I TOOK OUT THE BATTERY WHEN I PUT IT BAK IN THE CAR STARTS TRACKLING LOW AND SHUTS OFF...NEED HELP ASAP PLEASE THANKS
Drives: Yaris sedan Join Date: Aug 2014
My Yaris if the idle gets too low the a/c stop cooling and if I put in neutral and accelerate it’s start cooling again. I’ll give a try in that screw to see if work better.
| DIY - 1.8L 1ZZ-FE TB Connector Chip Swap | Yaris T-Sport | DIY / Maintenance / Service | 332 | 04-03-2022 01:39 AM |
| Cold Idle Speed Question... | cpnnz | DIY / Maintenance / Service | 9 | 11-04-2009 05:31 PM |
| what is the idle speed on stock 09 HB | ezhacker1 | General Yaris / Vitz Discussion | 5 | 05-17-2009 08:49 AM |
| Help with low idle from Venezuela | Yarisvene | DIY / Maintenance / Service | 5 | 06-23-2007 08:23 AM |
| Low idle speed | gonzo452001 | DIY / Maintenance / Service | 9 | 02-21-2007 08:41 PM |
