#37 |
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
I still want to know what 8" sub SQ was talking about. ??
#38 |
![]() ![]() ![]() ![]() ![]() ![]() Yeah me 2! .
. CLA 250, 4MATIC |
#39 |
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
I've heard you can pull the edge of a towel or wash cloth behind it and it will snag on that clip and pull it out. Haven't tried it yet as I have not yet needed to take my door panel off.
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
#40 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
where can i get the tool to remove the clip....i've tried with a towel...but it has failed
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#41 |
I used to do it just using a flat screw driver!
. CLA 250, 4MATIC |
#42 |
i'll try with just a screw driver....you took a smal one ? I've tried with something slim but never find the clip..
#43 |
Roadrunner Jr.
Digital Designs 1508
Pretty damned loud...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#44 |
. CLA 250, 4MATIC |
#45 |
DD's are Beast !!!!
#46 |
Roadrunner Jr.
We are planning on using 8 of them vented in this '82 Malibu wagon we have going on at the shop.
That should get a little loud with the 6K watts we have going on...
#47 | |
D.
. CLA 250, 4MATIC |
#48 |
wooowwwww i completely forgot yarisworld :O i did not came since a long time :O
i ve made the clips removed at my toyota dealer as i went there for an oil change..... i've installed the pionner 6.5'' in the door i'Ve attached the tweeter to the door near the 6.5'' as you told me.... yesterday was a sad day.....come one drove on a red light and hurt my car.....i dont have front bumper anymore...my car went to the toyota dealer today...ill get it back soon ! I HOPE About the sound it gives .....wellll its not as good as i tought......the 6.5'' sound great until I reach 25/35 of volume.....ans they are not amplified.....they are wired to the stock wire....with the 12db crossover.... they kind of make unpleasant noise...scratching noise ....the tweeter also make it...but not as much..... maybe its because of the door box...or no thing deadended....or the stock wire.....
#49 |
I'm sorry to hear about the accident.
I hope you are ok. Yes, the Pioneer (Premier 6.5 components) are hungry for power, same for the Hifonic tweeters! D.
. CLA 250, 4MATIC |
#50 |
So.....what do I need to do to make them sound better....
#51 |
AMPLIFICATION! get a good amp.
Did you install the EQ-6500? Are you running your speakers out of your deck? D.
. CLA 250, 4MATIC |
#52 |
I haven't insalled the eq6500 since i dont know where to mount it...and I dont have ampli for the speaker....they are actually wired to the stock wire...so...out of the deck...!
where had you mounted it ? what kind of good amp should i buy....an amp that i could do a 3-way component like yours but later on! thanks
#53 |
I'm running 87 watts rms to my Hifonics components, and they sound okay, I'm fixin to add some cheap NB 1 tweeters to catch the high hats and some of the other higher frequency sound on the music, to help even out the hi's. Them lil cheap things are 97 db sensitivity so i can get away with just running them off the deck power. Check on Amazon for a 4 channel amp, i got mine for under 100 bucks, but i'm also going with an Okay brand, not top of the line stuff like Sqcomp and Derick. My amp is a Crunch 1400.4 I went with Maxxsonics amps. I also have a 1200 Brutus for the subs. Maxxsonics also makes Mb Quart, which is the top of the line brand for Maxxsonics. They also manufactured the Autotek brand as well. I want to go on ahead and just grab the 2000 watt brutus, but i don't think i can provide the power to feed that amp. Once i can stay around 14.4 Volts, then i'll consider the bigger amp.
#54 | |
Since you all ready have a Hifonics you could get a HFi100.2 and run passive 100x2 into the 6.5 + Tweeters Passive means that you are going to use the x-over between the amp and the speakers. HFi100.2 LINK ![]() You could still run passive with a 3 way system with a x-over and not breaking the bank going Active, and still use only 2 amps 1 for the sub and 1 for the speakers (Mid-bass 6.5", 3" mids, tweeters) Then if you really want to go 3 way active, it's a complete different story. D.
. CLA 250, 4MATIC |
| ACRONYM thread | Shroomster | Off-topic / Other Cars / Everything else Discussions | 45 | 02-15-2025 10:30 PM |
| Yaris Sedan Deadening and Sound system upgrade | derickveliz2 | In Car Entertainment + Electronics (audio / video / alarm) | 2992 | 11-18-2021 02:14 AM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| Very Important Question about Sound System Upgrade. | Falconeer | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 07-07-2010 03:57 AM |
| Cheap sound system upgrade. I like it. | kac | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 06-22-2010 09:48 PM |
