Old 11-27-2010, 01:39 PM   #1
darkMINI
Drives: 08 hatch
Before you swapped the ECU was it just the Tach dial and pointer not illuminating, or both the Speedo and Tach dials/pointers?
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
darkMINI is offline   Reply With Quote
Old 11-28-2010, 05:18 AM   #2
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Lightbulb
after the swap, the gauge backlight, pointers(tach+speedo) is not working..Rest of the functions is working.
Below my observation:
My wiring harness is not the same. The canadian cluster has the illumination control and GCC/EU model don't have. To fix this, You have to swap/jumper or rig the illumination pinout of the new cluster.
I put it back my original cluster as I am annoyed without the illumination/backlight. Everything works fine. From here, I noticed also that they have different programming cluster daughter board. Tried to swap their daughter boards also but the results is more bad(none of the pointers is working).
ricepower is offline   Reply With Quote
Installing Speedhut tach, need help! RedRide DIY / Maintenance / Service 2 07-05-2009 04:02 PM
Canada tach in a US Yaris LB tiksman DIY / Maintenance / Service 49 02-27-2007 02:40 AM
