Old 02-07-2007, 08:19 AM   #1
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
Yeah I saw an ad in a magazine for a supercharger that looked a lot like a turbo turbine... are those any good?
you need to see the compressor map for that given unit to know how well it compares to the other superchargers on the market.
and it looked like the compressor not the turbine.
Russelt3hPirate is offline   Reply With Quote
Old 02-07-2007, 09:29 AM   #2
cdydjded
Drives: Yaris LB Turbo
I spoke to Oscar @ PRI & to the rep for Rotrex, its not going to happen unless all the pulleys are changed. Here the problem, the Yaris has 3 groove pulleys. The Rotrex need minimal 5 grooves. I had the brackets done before I spoke to the Rotrex rep. It fits without a problem. Just that changing the pulleys would make the kit expensive.
cdydjded is offline   Reply With Quote
Old 02-08-2007, 01:20 AM   #3
Oops wrong choice of words there
They have three different sizes available, this is for the mid-sized one:
http://www.rotrex.com/pdfs/Rotrex_Te...Range_V1.6.pdf
and for the small-size one:
http://www.rotrex.com/pdfs/Rotrex_Te...ange_V_3.5.pdf
Both of them should be applicable to our engines, according to their ratings. There's a lot more info at www.rotrex.com, if someone more knowledgeable then myself can take a look and share their opinion
Could we not use an aftermarket accessory pulley for a Scion (for example), which has the extra space for the power steering belt (which the Yaris does not use), and run it off that? If not, it should not cost all that much to get a custom pulley done, seeing what's available out there...
Old 02-08-2007, 12:15 PM   #4
yarisTOONR82
feed me knowledge!!!
Drives: 2007 Toyota Yaris 3dr HB.
does anyone know if the 1nzfe out of an 04 scion xb would work in a yaris?
yarisTOONR82 is offline   Reply With Quote
Yaris Engine Christopher General Yaris / Vitz Discussion 1 01-17-2007 03:14 AM
engine modify Yaris D-4D uraz Performance Modifications 10 04-30-2006 11:53 AM
