#55 |
![]() Drives: Yaris YRX Seadn Join Date: Nov 2010
I'm curious on how many of you run your Yaris on premium fuel. I have since the day I bought my Yaris and I get 19km per litre using cruise control and A/C off. My Yaris is a 1.5 lit auto sedan. I thank that's a bit over 51mpg. For those interested in cruise control, I had an Autostrada cruise control with steering wheel controls fitted to my Yaris with excellent results. So far I am very happy with the ubit.
#56 | |
Only Happy When it Rains
Colin Chapman disciple |
#57 |
![]() Drives: Toyota Yaris Join Date: Oct 2010
Personally I have done 57.9 mpg with my Yaris thats about 22km per liter
(7000km) Base 5spd no A/C with four people inside (close to 600 pounds) summer highway about 28degree C ....average speed about 90kph.
Thomas Paine Stage One Yaris TRDsway bar, TRD springs & shocks, TRD Quick shifter kit, TRD CAI, TRD oil & coolant cap Microimage light crank pulley, Agency Power steel braided brake lines. |
#58 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
#59 | |
Yea..thats mine
Drives: 2009 Yaris Sedan 5 speed Join Date: Sep 2010
"I'm sorry, were you driving there?" |
#60 | |
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
The drivers are relatively sane in their driving habits and don't go over posted 55 or 65 MPH limits. When I go on trips to big cities like Philadelphia or Pittsburgh... I always pick up the pace to accommodate the traffic flow there... they go well over the limits. Yeah, a lot of my hypermiling techniques are on State and Local roads. I lived in Miami, Florida for 28 years. It would be crazy to drive the way I do if I where still living down there! The flow of traffic there is 75-80 MPH, easily! Cheers!
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
#61 | |
"LibertyRides!"
![]() Cheers!
#62 |
ah, that i can understand. haven't been able to use unpoisoned gas for a long time sadly.
#63 |
"LibertyRides!"
50.412 MPG
Filled my car up this evening after the Northeast rains ceased! 9.819 to fill the tank with 495 miles driven. Came out to 50.412 MPG...
![]() What helped to break the 50 MPG barrier again was a trip over the Thanksgiving Weekend to see family and friends. Over 80% driving Highway. The other driving is my normal country roads to work. I'm also using non-ethanol gas. The gas station I fill up at still has around 1,500 gallons of premium non-ethanol gas. After they get below 500 gallons they will convert over to premium ethanol gas. Regular gas has already changed over to ethanol at this station. There is hardly any demand for premium gas... so I will keep using it until they convert. The weather wasn't too bad either... pretty mild for mid-November in PA. Cheers! Gas Tank mile increments (non-ethanol Premium gas used): 1st Bar drop (8/8) > 90 mi (9) 2nd Bar drop (7/8) > 70mi (160) 3rd Bar drop (3/4) > 55 mi (215) 4th Bar drop (5/8) > 90 mi (305) 5th Bar drop (1/2) > 60 mi (365) 6th Bar drop (3/8) > 60 mi (425) 7th Bar drop (1/4) > 70 mi (495) 8th Bar drop (1/8) > 0 Tank total: 495 miles Fuel used: 9.819 gallons MPG: 50.412
#64 | |
![]() ![]() Drives: '07 Yaris 5dr HB Join Date: Aug 2010
I'm just sayin'.... |
#65 | |
"LibertyRides!"
![]() You can't calculate each individual bar the same amount. The physical properties of the plunger is the reason for the different mileage points. Usually the first bar will be the largest... the tank can be topped and the plunger is at its highest level. I got 90 mi on my first drop. During my third into fourth bar drop I got 90 mi reading too. I was travelling to my destination on my trip at this time. On my sixth to seventh bar drop I was travelling home... the reason for the 70 mi reading. The fifth bar drop was highway driving visiting friend after I reached my destination while on Thanksgiving vacation break. ![]() Cheers!
#66 |
I hear ya! Still, the fact that you can get over 50 MPG on a single tank is quite remarkeable! Kudos to you!
Hopefully I'll be able to break to 50mpg barrier one of these days! I've been doing alot of reading in the fuel economy thread and have been applying many of the techniques I learnt on my daily commutes to and from work (about 50km daily) and the most I've accomplished to date is a mere 37mpg....How do you do it??? Does your Yaris run on water?? LOL! |
#67 |
Best I've ever had was in the 48-49 range.. cracking into 50+ is awesome!
http://www.youtube.com/user/ProjectYaris |
#68 |
"LibertyRides!"
I'm not your 'normal' driver. I drive extremely gentle on the accelerator and mostly highway miles. It helps that my driving hours are when the roads are empty. I can drive at my own pace. Also, non-ethanol gas for now... helps in MPG.
Fuel Efficiency and the Yaris: http://www.yarisworld.com/forums/showthread.php?t=5979 Using DFCO to increase your MPG: http://www.yarisworld.com/forums/showthread.php?t=4248 These are two (2) excellent Stickies! IF you follow the hypermiling techniques in these stickies you will definately get the miles... ![]() Cheers!
#69 |
toyota
this is so close to what im getting but in kilometers..lol seriously are you sure its not in km.. coz every single bar is identical to my km/bar...in winter ofcourse
Gas Tank mile increments (non-ethanol gas used): 1st Bar drop (8/8) > 102 mi (102) 2nd Bar drop (7/8) > 86 mi (188) 3rd Bar drop (3/4) > 50 mi (238) 4th Bar drop (5/8) > 62 mi (300) 5th Bar drop (1/2) > 74 mi (374) 6th Bar drop (3/8) > 72 mi (446) 7th Bar drop (1/4) > 52 mi (498) 8th Bar drop (1/8) > 0 Tank total : 498 miles Fuel used: 9.662 gallons MPG: 51.542[/QUOTE] |
#70 | |
"LibertyRides!"
Maybe America pulled a fast one on all of us and decided to go the easier measurement way... metric ;-) ![]() Canada winter... ouch! Warmer in this latitude. Nope... These are US Gallon/Mile log figures... Really ![]() Cheers!
#71 |
toyota
wow......
#72 |
Yup, these loooong canadian winters really don't help mileage....
| 3000 mi Summer Trip Log...MPG included! | slothman86 | Fuel Economy Forum | 14 | 07-20-2010 12:15 PM |
| Finally broke 40 mpg | brg88tx | Fuel Economy Forum | 5 | 07-16-2010 08:34 AM |
| Better MPG in the City vs. Hwy | Loren | Fuel Economy Forum | 21 | 01-29-2010 11:49 AM |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| Anyone from Missouri? MPG problems inside | 4MPG | Fuel Economy Forum | 31 | 12-17-2008 05:48 PM |
