![]() ![]() Drives: 2008 Yaris HB Join Date: Nov 2010
ok the picture is the wires and locations
Driver Side ----- White green Brown off - 14 -- 14 -- 14 low 5 -- .4 -- 9 hi -- 4 -- 9 -- .5 Pass Side ----- Black Blue Brown off - 14 -- 12 -- 12 low - 14 -- .3 - .3 hi -- 14 -- 8.77 -- .67 hoipe the chart is useful, Thanks for helping. i can't say that enough CT |
I forgot o load the picture. Sorry
these are the numbers taken with the opposite side detached. sorry it took all day.
Driver Side ----- White green Brown off - 11.2 -- 11.2 -- 11.2 low .22 -- .22 -- .22 hi -- .02 -- .02 -- .02 Pass Side ----- Black Blue Brown off - 13.8 -- 13.8 -- 13.8 low - 13.7 -- 13.7 - 13.7 hi -- 13.4 -- 13.3 -- .47 |
No problem. Try pulling just the passenger bulb and then turning on the headlights to see what the driver's side bulb does in the three states with the other removed.
gonna do that on my lunch break...
here is the picture |
oh and the white wire is actually grey
Hmmmmmm. I am still reallllly thinking that the H-LP/AMT Relay might be the culprit.
With the bulbs both in, the charts should look like the following: Driver Side ----- Grey Green Brown off - 12 -- 12 -- 12 low 12 -- 12 -- .4 hi -- 12 -- .7 -- 12 Pass Side ----- Black Blue Brown off - 12 -- 12 -- 12 low - 12 -- .4 - 12 hi -- 12 -- 12 -- .7 On yours, the low beam power is not being properly switched. On a working car, if you pull the relay, the high beams will work, but the low beams will not turn on at all (which is basically what you are seeing). One last thing to try before replacing the relay is to unplug the DRL module's connector.
I disconnected the drl box and nothing. If Toyota is open tomorrow I will go get a relay. Or auto zOne. Some place like that hopefully has it
If you can find a way to jump the two large blade slots together, while the headlights are on, and on low beam, you can do a final check to make sure that that relay is truly bad (since it is a $30+ relay).
Wow. Sparks! Lol I'm ok. But the headlight stalk was in off position and when I connected the two the lights came on. That was suprising! But it didn't fix it. Every time I think it will work It doesnt. Oh well. What's next?
I meant to say ONLY connect the jumper with the headlight stalk on and in low beams. In that state, did the lights come on?
Another thing. I went put and pulled the relay. And the high beams do still come on, but the driver side lamp is still turning on both filaments. And they are still dim, really dim.
ugly....
#14 |
i fixed it! lol, Thanks CT.... all i had to do was total it. problem solved.
#15 |
No way! There seems to be way too much of that going around lately.
#16 | |
![]() Drives: Yaris 2005 Join Date: Jan 2011
May I ask how you fixed it? I don't understand what 'total it' means in your summing up sentence "Thanks CT.... all i had to do was total it" :/ :) Cheers. |
#17 | |
With your, have you checked the bulbs? The most common reason for no low beams is that both bulbs have burned out their low beam filament.
#18 | |
I was thinking that the fact they both stopped working at the same time was too much of a coincidence, but the cost of new bulbs makes the most sense to test first. Cheers. |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| aftermarket headlights | be_ha | Cosmetic Modifications (Exterior/Interior) | 0 | 10-03-2010 03:06 AM |
| Best Aftermarket Headlights | MadMax | Cosmetic Modifications (Exterior/Interior) | 3 | 06-04-2009 06:50 PM |
| Angel Eyes headlights | Danish Yaris | Cosmetic Modifications (Exterior/Interior) | 9 | 02-13-2009 09:15 AM |
| JDM headlights | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 6 | 02-13-2007 10:52 AM |
