Old 12-02-2011, 06:54 AM   #1
SimTronik
Machinist
Drives: Yaris sedan 2010
Perfect thanks! Any tips what to avoid with the airbag?
SimTronik is offline   Reply With Quote
Old 12-02-2011, 07:33 AM   #2
Just make sure that you disconnect the negative battery terminal and wait a couple of minutes before disconnecting the airbag, and when you remove it, set it down on its frame, rather than on the Toyota logo.
Old 12-03-2011, 05:34 PM   #3
SimTronik
Machinist
Everything is plugged in and back on its place but i cant remove the steering colum cover. i think its because the wheel is in place? So i cant check for the d3 pins. Can i just road test it lol? or it is risky?
Old 12-03-2011, 05:43 PM   #4
You can just road test it, or better yet, turn the ignition to ON, press the on/off on the stalk, and see if the indicator comes on.
Old 12-03-2011, 06:03 PM   #5
SimTronik
Machinist
It works! Can beleive i have a cruise control for 40 bucks :) Thanks sir.
Old 12-09-2011, 01:00 PM   #6
33OH
Drives: '08 Yaris
Scott, can you PM me what all I'd need to run this on my 2008 Yaris LB 5 speed? Interested but not sure if the wiring would be over my head.
Old 12-09-2011, 01:05 PM   #7
You can definitely handle it. With my DIY many who have never touched any wires in a car have self installed it.
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 12-09-2011, 01:23 PM   #8
A-Dingo-Ate-My-Baby
Drives: yaris
protip
for the two screws, you can use 2 standard server rack mount screws
found in most computer rooms or racks....
they are typically the same size and thread pitch, and short enough as well
that is what I used on my cruise control after digging through my junk drawer
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 12-09-2011, 09:26 PM   #9
deathwisher
Drives: 2007 Yaris Sedan
Originally Posted by A-Dingo-Ate-My-Baby View Post
protip
That depends on if you are in Canada or US... >.> Canada's server rack uses #10-32 screws. I can't remember which one the US ones used...
deathwisher is offline   Reply With Quote
Old 12-14-2011, 12:22 AM   #10
GAAzureMach1
Converted Gearhead
GAAzureMach1's Avatar
Drives: 2010 Yaris HB 3 Door Base Red
Hey Scott, I have a 2010 HB 3dr L Automatic with the convenience package. Can you pm me with cost and payment info?
Thanks, Todd
Commuter -10 Toyota Yaris, HB, 3 Dr, Base, auto, Red
Track Queen -03 Ford Mach1, 1UP, 4.6 DOHC V-8, TR-3650 5 spd Man, Azure Blue, Highly Modded
Grocery Getter -02 Ford Excursion, Ltd, 6.8 SOHC V-10, 4R100 Slush Box, Forest Green, Few interior mods
Tow Pig - 94 Ford F350, XLT, 4 Dr, Crew Cab, 2wd, 7.3 idi diesel, E40OD Slush Box, Bright Red, Mildly Modded
GAAzureMach1 is offline   Reply With Quote
Old 12-15-2011, 02:20 AM   #11
YAR1S
YAR1S's Avatar
soooo are these plug and play for 2007 liftback? *crosses fingers*
-Jen <3
Old 12-15-2011, 06:54 AM   #12
Yes. There is a little bit of wiring that needs to be added for 06-08 Yaris, but it is just a matter of adding a couple of pins to two connectors and running the wire from the ECM to the steering column. Take a look at my DIY to see exactly what's involved:
Old 12-25-2011, 12:26 PM   #13
thestranger
Drives: 09 3-door LB/MT
hey Scott, I know I'm like a year late... got an '09 lb/mt. any more stalks for sale? :)
thestranger is offline   Reply With Quote
Old 12-25-2011, 09:05 PM   #14
Yes. I still have plenty.
Old 12-31-2011, 08:06 AM   #15
GAAzureMach1
Converted Gearhead
money sent.
Old 01-06-2012, 08:49 PM   #16
GAAzureMach1
Converted Gearhead
Smile
Scott I got it in the mail today. Took me 20 mins for the whole install. Easiest mod I have ever done. Thanks a bunch!
Old 01-22-2012, 01:06 PM   #17
ttr125fan09
ttr125fan09's Avatar
Drives: yaris
if you have any left for sale, i would be interested
ttr125fan09 is offline   Reply With Quote
Old 01-22-2012, 01:37 PM   #18
I do still have some.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Can we do this? (aka The DIY Cruise Control Thread) mrbond DIY / Maintenance / Service 502 07-22-2017 02:57 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
