Old 06-28-2013, 11:33 AM   #1
jayeh
Drives: '08 Yaris LB
Originally Posted by ToyotaBuzz View Post
Did he install it?
Yes.
jayeh is offline   Reply With Quote
Old 06-29-2013, 01:15 AM   #2
Originally Posted by jayeh View Post
I just took mine to be installed today and the installer took one look and said its a cheap Chinese knockoff. Any ideas?
I have no idea why he would say that, as it is genuine OEM stalk. The only thing that might have made him question it is the horn wire, which I add, to save people the hassle of breaking the pin to pull their's out of the original connector.
Old 07-03-2013, 09:45 AM   #3
isidoro
Drives: HDS
Hello CTScott
I write from another part of the world “italy”
I are desperate
I know that we are talking only of yaris
but you are the experts on Cruise Control that I found
I own a hybrid Auris HSD 1,8L
I put all the parts needed as the model with the standard Cruise Control
when I press the button on/off, the lights Cruise Control lights up green
but just release the brake I get a yellow triangle and the following “check Cruise Control “
do you have any advice for me???
thanks so much in advance
foto http://tinyurl.com/nfsms5n
isidoro is offline   Reply With Quote
Old 07-03-2013, 03:43 PM   #4
Originally Posted by isidoro View Post
Hello CTScott
I are desperate
I will have to do some research for you when I return. I am currently in Northern Europe on holiday.
Old 07-25-2013, 07:09 AM   #5
isidoro
Drives: HDS
Hello CTScott
I are desperate
Hi CTScott
problem solved
found missing wire
between ECU and brake switch
Bye isidoro
Old 07-03-2013, 04:02 PM   #6
isidoro
Drives: HDS
OK
good vacation
we update when you return
Isidoro north italy
Old 07-10-2013, 09:54 AM   #7
isidoro
Drives: HDS
while visiting europe
if you go to Northern Italy
I'll pick you??
I am close to Bergamo, which has the largest airport
where land all European flights
Bye-Bye!
Old 07-11-2013, 12:43 AM   #8
I'll pick you??
Bye-Bye!
I am a bit more North: England, Denmark, Sweden, Estonia and Russia.
Old 07-10-2013, 03:55 PM   #9
rapev-8
Drives: toyota
do u have anymore?
rapev-8 is offline   Reply With Quote
Old 07-11-2013, 12:45 AM   #10
Originally Posted by rapev-8 View Post
do u have anymore?
Yes
Old 07-13-2013, 01:42 PM   #11
Jadijkstra2000
Drives: Toyota Yaris 2010
Do you have more? :)
Jadijkstra2000 is offline   Reply With Quote
Old 07-13-2013, 04:47 PM   #12
Yes
Old 07-14-2013, 04:19 AM   #13
Jadijkstra2000
Will it work on european Yaris 2010?
Old 07-16-2013, 10:13 PM   #14
My understanding is no, but a person from Germany recently ordered one from me, as he was told that it would work. I will let you know when I hear back from him.
Old 07-14-2013, 06:30 PM   #15
Hayabusaboy
Drives: 2007 white hatchback
Was reading thru a few treads, seems your saying that all yaris have the hard wiring from the factory, correct? I have a 07 hatchback auto trans. If all i need is this kit your selling i'd like to purchase one, if you still have some available. Pay pal ok? Thanks Bruce
Hayabusaboy is offline   Reply With Quote
Old 07-16-2013, 08:47 PM   #16
lanemeyer14
Drives: 08 base Hb
I'm interested in one as well if still available. Will be for an 08 liftback 5spd
lanemeyer14 is offline   Reply With Quote
Old 07-17-2013, 09:17 AM   #17
Jadijkstra2000
Number of the ECU is : 89661-0dd90
Hope it can work :) Would be nice
Old 07-18-2013, 05:57 PM   #18
Jadijkstra2000
It looks like the car already has the clutch switch installed, i cannot have it started when the clutch is not pressed... So i guess that one is installed...
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Can we do this? (aka The DIY Cruise Control Thread) mrbond DIY / Maintenance / Service 502 07-22-2017 02:57 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
