Old 07-18-2013, 09:03 PM   #1
Originally Posted by Jadijkstra2000 View Post
It looks like the car already has the clutch switch installed, i cannot have it started when the clutch is not pressed... So i guess that one is installed...
The cruise control clutch switch is different. The starting one requires the clutch to be pressed completely to trigger, where the cruise control one triggers as soon as the clutch switch is touched.
Old 07-21-2013, 08:01 AM   #2
Jadijkstra2000
Drives: Toyota Yaris 2010
ah alright, didn't know that, thanks :) are there ways to check if the car is prepared for cruise?
Jadijkstra2000 is offline   Reply With Quote
Old 07-21-2013, 12:13 PM   #3
The best test is to check the voltage on pin 40 of the A21 ECM connector (see my DIY below for that location). If there is 12 V on that pin with the ignition on, then cruise is present.
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 07-23-2013, 10:35 AM   #4
Jadijkstra2000
Do I need to remove the A21 connector to do the test or leave it in place for testing?
Old 07-23-2013, 01:58 PM   #5
Leave it in place. You will need to pull the rubber plug if there is not a wire present, so you can stick a piece of wire in to take the measurement.
Old 07-28-2013, 12:50 PM   #6
Mommas Yaris
Drives: 2012
Just wondering if you have any of these left and if you do how much? If you do would you please comtact me though my email @ cgoretx@gmail.com
Mommas Yaris is offline   Reply With Quote
Old 07-28-2013, 08:35 PM   #7
email sent.
Old 08-20-2013, 12:20 AM   #8
xboxer
Drives: 2007 Yaris Liftback Auto
Same question as above, including the OEM Stalk CC Pin Kit, and Cruise Control Indicator Module. Please send PM. Thanks
xboxer is offline   Reply With Quote
Old 08-20-2013, 06:26 AM   #9
PM sent
Old 03-18-2014, 12:08 AM   #10
Tylard
Drives: 07 Yaris
Interested in purchasing
Do you still have any these?
07 sedan m/t. Cost as well. Thanks
Tylard is offline   Reply With Quote
Old 03-18-2014, 06:20 AM   #11
Yes. PM sent.
Old 03-21-2014, 09:52 AM   #12
z0mb13k1ll
z0mb13k1ll's Avatar
Drives: '15 Dodge Challenger
ive got a 2007 sedan, can you pm me with the price and what i would have to do to install? thanks
z0mb13k1ll is offline   Reply With Quote
Old 03-21-2014, 10:34 AM   #13
PM sent
Old 03-22-2014, 07:11 PM   #14
Tylard
Drives: 07 Yaris
Super fast shipping, install not too bad, fishing the wires was def the hardest part. But I cant seem to get it to function on my 07 m/t sedan. I have tried rechecking all the connections and triple check the clutch switch to ensure it is fully pressed in when the my foot is off the clutch pedal.
Any suggestions of what to check?
My wire coming out of pin 40 on the ECM is hooked up and ran through the firewall. I connected this directly to the wire coming out of the slot 1 of the D3 connector. Is this ok or do I need a different wire? If so what is it where do I get it
Old 03-22-2014, 07:17 PM   #15
Double check your pin 1 and pin 2 locations per my DIY (http://www.yarisworld.com/forums/showthread.php?t=33750)
Also, with the ignition switch in the ON position, you can measure the voltage on the pin1 wire and will see 12V if it is connected properly. (Pin 1 is the one that goes to pin 40 on the ECM connector).
Also, double check your pin 40 to make sure you didn't install it on the opposite side of where it belongs.
Old 03-22-2014, 09:02 PM   #16
Tylard
Drives: 07 Yaris
Checked pin 1 and 2 and Im happy with them. Rechecked pin 40 also happy with that.
Checked the voltage. I put my red lead on the connection between the pin 1 wire and the pin 40 ecm wire. Then I put my black lead on the bolt where pin 2 from the d3 connection is mounted. I get 12 v with the ignition turned on. Holding and toggling the cruise on/off switch does NOT make change and still reads 12 volts.
Where the pin 2 wire is mounted there is a black lead already connected to that, I just added on the pin 2 wire and put the bolt back on.
Old 03-22-2014, 09:49 PM   #17
Ah, the pin 2 wire is the "other side". It is the ground for the system.
The black wire is not pin two. It is in the opposite row from pin 2. In this picture you can see the blue wire in pin 1 and the brown in pin 2:
Old 03-22-2014, 09:58 PM   #18
Tylard
Drives: 07 Yaris
My D3 connector looks just like the one pictured. The wires sent are different colors but going off the colors shown in the picture. The blue one connects directly to the A21 pin 40 wire. The brown one goes to a bolt (for grounding).
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Can we do this? (aka The DIY Cruise Control Thread) mrbond DIY / Maintenance / Service 502 07-22-2017 02:57 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
