Old 12-21-2010, 11:02 AM   #9
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
If you bought the car used and the jack and iron are MIA, any 2-Ton trolley jack and a cross type tire iron with a 21mm socket (from a local auto parts store) will be sufficient for changing and rotating your wheels. (given that you have stock wheels and lugnuts)
Even though it is heavier than the scissors jack from Toyota, I prefer the stability of the trolley jack when changing wheels at home, and the cross type wrench allows me to put more torque on the lugs to get them off.
If you want to spend less, goto a salvage yard for a Toyota scissors jack and lug wrench from most any of the economy models. (Yaris, Corolla, Tercel, Scion XB and XA)
SpaceShot is offline   Reply With Quote
help!, tire iron, tires
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
'54 T2 Yaris 1.0 VVTi automatic clutch / gearbox / starting problem Lettuce UK 0 09-30-2010 06:21 AM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
So how do you like the BIG SMILE on the 07 Sedan???? Ziv General Yaris / Vitz Discussion 3 02-03-2006 11:12 AM
