Old 02-11-2007, 03:43 PM   #1
tekmoe
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3
Send a message via AIM to tekmoe
aem or trd intake
what are the advantages/disadvantages? as far as i can tell, both of these intakes are exactly the same except for the price. aem is almost $100 cheaper.
i'd like to buy either intake to accommodate my trd exhaust...just trying to figure out which one i should get.
thanks in advance.
tekmoe is offline   Reply With Quote
Old 02-11-2007, 04:53 PM   #2
bigsky2
Cousin Vitz
bigsky2's Avatar
Can't go wrong with either one!
Personally I feel the bypass valve is not necessary for the Yaris intake, becase the filter is in an area that is well protected from excessive water or moisture entry.
It will not become completely immersed in water if you are driving through light/heavy rain. You really have to push the car through a 3 foot high body of water before the filter is affected.
My 2 cents.
Old 02-11-2007, 05:22 PM   #3
ChinoCharles
Drives: LB
About a month ago I hit one hell of a puddle in my area. It wasn't really that big, but in a lowered Yaris it felt like I was driving through the red sea. This basically scared me into wanting that bypass valve.
Old 02-11-2007, 06:04 PM   #4
nester
I made a post!
Drives: 2006 Scion tC-t
Send a message via AIM to nester
We recommend the Fujita intake. You know they love the yaris when they could pick one car to be in their booth at SEMA, and it was a Yaris.
nester is offline   Reply With Quote
Old 02-11-2007, 06:08 PM   #5
sf180th
Back in USA in days!
sf180th's Avatar
Drives: 07 Yaris S Sedan
Send a message via Yahoo to sf180th
I installed the Fujita intake this past week, cant say enough good things about it.
Kazera KZ-V Silver Rims, with 215-35-18 Kumho ESCTA ASX, TRD Springs, TRD Sway Bar, Fujita CAI, Blitz R-Vit i-Color, Blitz Throttle Controller, Megan Header, 2.25 Stainless Cat back Exhuast, 50 Series Flowmaster muffler, 6000k HID.
sf180th is offline   Reply With Quote
Old 02-11-2007, 06:18 PM   #6
cdydjded
Drives: Yaris LB Turbo
I have the AEM & it improved the car significantly.
Old 02-11-2007, 07:12 PM   #7
FlintArrow
Drives: Flint Mica 2007 Yaris S M.T.
AEM's bypass valve is a debate in itself.
Most performance enthusiasts arent a big fan due to lack of flow and I have heard some functionallity problems alike.
TRD is a great name to have on your vehicle but as noted before: its the same as the AEM. If it was me and I had to have the TRD I wouldnt install the bypass valve and would just stay away from river crossings.
If you dont submerge it you wont hydrolock your engine. It takes quite a bit of work to do this for most public roads and often times you can probably make the state pay for the engine.
Otherwise the AEM CAI is a great choice or perhaps the Weapon R short-ram if you dont want to risk it.
The HUGE advantage that AEM has over everyone for the Yaris is its Dryflow filter. Oil and MAF sensors do not get along and most K&N style filters or foam oiled units will eventually require a MAF cleaning.
The AEM Dryflow only comes with the AEM intake...the TRD intake comes with their older oiled (red/pink color) variant.
FlintArrow is offline   Reply With Quote
Old 02-11-2007, 08:49 PM   #8
Lafiro
Drives: 06 Yaris Sedan
I have a question that I could never get an answer to since I actually never even asked...
I want to get a S/C or a turbo in the future.
Does getting a CAI affect this? Or will the S/C or Turbo take care fo the intake so the use of an aftermarket one is not needed?
Old 02-13-2007, 01:40 AM   #9
FlintArrow
It depends.
Any SC or turbo kit will change the mounting point of the intake system. However, you can still modifiy it to work with the existing unit.
We have a AEM short ram intake on my Dad's 2002 SVT Focus (jackson supercharged). We just had to take a chop saw to the end and snug up the silicone coupler a bit higher. Still, its a nice intake tube with a maf sensor fitting and a non-oiled filter...TONS better than a cruddy plastic black box.
If you might go down the forced induction road dont worry about a $150-250 loss...you will spend thousands on the kit and installation/tuning. If you want to ebay the used unit or throw it away it wont exactly be your largest expense.
Good Luck. I would just get the CAI or short ram and enjoy the extra noise until you pull the trigger on on the F.I. Kit.
Old 02-11-2007, 10:16 PM   #10
cdydjded
When you have a turbo or S/C you cannot use a CAI like a AEM or TRD
Old 02-12-2007, 12:22 PM   #11
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Why not?!
2006 Red Blitzed RS 5-door
Old 02-12-2007, 12:39 PM   #12
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
Originally Posted by Doc Zaius View Post
Why not?!
Because the inlet for the throttle body will be moved with a supercharger and the intake no longer goes to the same area with a turbo. It goes to the inlet of the turbo.
Nimble is offline   Reply With Quote
Old 02-12-2007, 02:14 PM   #13
tekmoe
ex-yaris owner
i went ahead and ordered the TRD intake just because i already have the TRD exhaust, struts, springs, and quickshifter. i figured i might as well make everything match.
label me the TRD wh0re whydontcha?
Old 02-12-2007, 03:18 PM   #14
bigsky2
Cousin Vitz
bigsky2's Avatar
You must be the American cousin of echo_hrs
He's also a TRD Purist
Old 02-12-2007, 03:20 PM   #15
Nimble
Not a bad move.
Old 02-12-2007, 02:14 PM   #16
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Makes sense... thanks.
Old 02-12-2007, 07:44 AM   #17
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
probably gonna go with the trd since i get a awesome deal on the parts. but we work with fujita intakes for our scions so its a toss up right now.....
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 02-19-2007, 05:38 PM   #18
Yar
Drives: 07 Bayou Blue Metallic
I have a quick question.
I live in Canada, and have looked into installing a CAI into my yaris. I heard that ordering a TRD CAI through my dealer is just gonna cost me an arm and leg, because of duty charges, etc.
What i'm wondering is, can i buy a TRD CAI from a 3rd party vendor, and have my dealership install it, and still be under warranty?
Thanks
-Bill
Yar is offline   Reply With Quote
AEM INTAKE ***UPDATE*** riceboy Performance Modifications 30 09-10-2007 08:35 PM
TRD Parts MC-BPT Sponsors Classifieds Area 9 06-23-2007 11:51 AM
PICS OF TRD INTAKE INSTALLED! elsteverino889 Performance Modifications 9 03-03-2007 05:12 PM
AEM Cold Air Intake!!! BulletProofAuto Sponsors Classifieds Area 18 09-19-2006 10:33 PM
AEM Cold Air Intake Toddhata Performance Modifications 18 08-08-2006 04:02 PM
