![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
I haven't insalled the eq6500 since i dont know where to mount it...and I dont have ampli for the speaker....they are actually wired to the stock wire...so...out of the deck...!
where had you mounted it ? what kind of good amp should i buy....an amp that i could do a 3-way component like yours but later on! thanks
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
I'm running 87 watts rms to my Hifonics components, and they sound okay, I'm fixin to add some cheap NB 1 tweeters to catch the high hats and some of the other higher frequency sound on the music, to help even out the hi's. Them lil cheap things are 97 db sensitivity so i can get away with just running them off the deck power. Check on Amazon for a 4 channel amp, i got mine for under 100 bucks, but i'm also going with an Okay brand, not top of the line stuff like Sqcomp and Derick. My amp is a Crunch 1400.4 I went with Maxxsonics amps. I also have a 1200 Brutus for the subs. Maxxsonics also makes Mb Quart, which is the top of the line brand for Maxxsonics. They also manufactured the Autotek brand as well. I want to go on ahead and just grab the 2000 watt brutus, but i don't think i can provide the power to feed that amp. Once i can stay around 14.4 Volts, then i'll consider the bigger amp.
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
#3 | |
Since you all ready have a Hifonics you could get a HFi100.2 and run passive 100x2 into the 6.5 + Tweeters Passive means that you are going to use the x-over between the amp and the speakers. HFi100.2 LINK ![]() You could still run passive with a 3 way system with a x-over and not breaking the bank going Active, and still use only 2 amps 1 for the sub and 1 for the speakers (Mid-bass 6.5", 3" mids, tweeters) Then if you really want to go 3 way active, it's a complete different story. D.
. CLA 250, 4MATIC |
| ACRONYM thread | Shroomster | Off-topic / Other Cars / Everything else Discussions | 45 | 02-15-2025 10:30 PM |
| Yaris Sedan Deadening and Sound system upgrade | derickveliz2 | In Car Entertainment + Electronics (audio / video / alarm) | 2992 | 11-18-2021 02:14 AM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| Very Important Question about Sound System Upgrade. | Falconeer | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 07-07-2010 03:57 AM |
| Cheap sound system upgrade. I like it. | kac | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 06-22-2010 09:48 PM |
