Foglight Power Source
I need a location to draw 12 volts (preferably in ACC) for my foglights. Until yesterday I had it hooked up to the ACC spot in most tutorials (also part of the fuel pump fused circuit), however it suddenly stopped working. I'm looking to use an add-a-fuse on the fuse panel, but don't know which spot will support them.
Since our bulbs use 80W, am I correct in assuming the amperage is 80/12 = 6.5ish amps? |
You can use connector 4F - Pin 5, which is a light blue wire. It is the ACC switched feed to the CIG and ACC fuses and is fed by the 25A AM2 fuse.
Not quite a noob
Why not directly off the battery?
![]() ![]() Drives: 2008 5 Speed Sedan Join Date: Jan 2011
It could be the fact that I've got a Canadian version of the Yaris sedan, but in the engine bay, coming off the headlight harness is a second plug that has 3 (maybe 4) pins on it on. isn't this pre-wired for fog lights? - I haven't added mine yet but hope to this spring
The US yaris is the same for the under hood wiring. I believe he's working on the coil side (switch side) of the fog light circuit, as opposed to the contact side (bulb side). I also think that he used the harness included with the aftermarket fogs, as opposed to the OEM wiring method.
I'm actually not even using a relay. Just +12v from ACC to a switch out to the fogs.
Thanks CTScott. Your electrical genius never ceases to amaze me. |
Drives: Toyota Belta SCP92 Chasis Join Date: Jan 2011
Hi I have a Toyota BELTA(SCP92, 1300cc, X grade) car. Need to fix the fog lights. Can I get the correct wiring points & directions how to get the switch connected. Can some one help me out.Tks.
Amal |
Do you have the OEM fog lights or an aftermarket kit?
| Removal of the Factory Integrated Source | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 08-24-2010 12:44 AM |
| Finding a usable power source | Taiyaki | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 05-25-2009 09:37 PM |
| Possible Revolutionary Power Source...Aquygen | nsmitchell | General Yaris / Vitz Discussion | 7 | 06-20-2007 07:32 AM |
| POWER WINDOW POWER SOURCE IN DOOR PANEL? | mrrock | DIY / Maintenance / Service | 5 | 03-21-2007 06:27 PM |
