Old 01-24-2011, 12:42 AM   #109
Originally Posted by samltd View Post
I see; thanks for making things clear.
It seems that the horn will wait.
Is there a possibility to connect the transponder key bypass to the other STATUS wire (4-pin satellite harness diagram/1 BLUE (-) STATUS OUTPUT)?
Then to program the remote module to start the rear defogger and the engine together? Or to connect the second STATUS wire to the defogger wire?
I would like to have the rear defogger working with the remote, when the heating is on during winter time.
Tx
Either should work. The defogger (-) wire is the black wire on the defogger switch, BTW.
Old 01-25-2011, 01:09 PM   #110
samltd
Drives: yaris
Thanks, I have few more questions.
Running a wire behind the A/C panel to the switch, or better trying to find the wire's other end and to connect over there?
The neutral switch is necessary for an automatic?
Where the hood switch goes actually and where do I pass the wire from the remote start module to it?
Regards.
samltd is offline   Reply With Quote
Old 01-25-2011, 01:33 PM   #111
Regards.
I would connect at the back of the AC panel, as that is easy to get to. The next to points are connector 1E (which is up high under the dash) and 4Q (which is buried under a cover on the back side of the under-dash fuse panel).
Autos do not need a neutral wire, since they will only start in neutral.
The hood switch (should you choose to install it) needs to mount where it will be pressed when the hood is closed. And, the base of it needs to be in contact with bare metal (or needs to have a ring terminal connection to a ground point). You can run a wire to it by going through the giant grommet that is up by where the steering column goes through the firewall.
Old 01-26-2011, 05:49 PM   #112
samltd
Drives: yaris
Will do how you say
Thanks a lot.
Old 04-07-2011, 10:41 AM   #113
bad_bwoy007
bad_bwoy007's Avatar
Drives: 2010 8T0 Yaris Liftback
Ultrastart 1280 for Manual Transmission
Hey CTScott,
I just got an Ultrastart 1280 and can't wait to install it this weekend.
The manual:
http://www.ultrastarters.com/Feature...L-REV-2008.pdf
Did you have to cut any wires in terms of connecting to the starter and ignition wires of the car?
I have a 2010 Liftback with no power or keyless entry.
Thanks to this forum i was able to complete my cruise control addition which has been amazing seeing that I drive 100 miles roundtrip to work everyday.
So back to the autostart, I got some wiretaps for the rest of the connections that are needed but I am a little unsure about the starter part and the clutch bypass.
This will be the third alarm I install and the other two were alot easier (no autostart).
Let me know how you got yours hooked up so that when I actually start the job it won't turn into a whole day event.
Thanks
bad_bwoy007 is offline   Reply With Quote
Old 04-07-2011, 11:26 AM   #114
Originally Posted by bad_bwoy007 View Post
Hey CTScott,
The manual:
Thanks
I didn't cut any on mine - All connections were just taps. But, if you are going to hook-up the anti-grind, then that is the one place where you have to cut and insert the remote starter connections in between. I typically don't bother hooking up the anti-grind on my own cars.
For the clutch bypass, you will wire it as a "type 3" where the normally open relay contacts will be connected to the yellow and black wires on the clutch switch connector (so those are taps, rather than cuts).
Old 04-07-2011, 01:21 PM   #115
bad_bwoy007
Thanks for the quick response.
So is this how the relay should be hooked up?
If so, what would you use as you 12 volt pulse to activate the relay?
The Starter output?
PIN-1 YELLOW Starter Output-This wire will test 0V when the key is off, in the Accessory position and when
the Ignition is in the on position. The starter wire is 12volts during the start/ crank position only.
Old 04-07-2011, 01:43 PM   #116
The Starter output?
Correct - The starter output wire should feed the relay coil.
Old 04-07-2011, 02:10 PM   #117
bad_bwoy007
Thanks for all the help. You are the man.
Old 04-08-2011, 08:32 PM   #118
bad_bwoy007
Installation Troubles
CTScott,
Got so troubles here with the install.
I'm just doing a quick test to see if I could get the system to start.
I have the:
Yellow(Output to starter circuit) to Black(Yaris - Starter)
Green(Output to ACC circuit) to White(Yaris - ACC)
Red
Red
*Both Red wires tapped together then into the 12v fuse location.
White(2nd IGN) to Pink(Yaris - IGN#2)
Blue(IGN circuit) to Green(Yaris - IGN#1)
For now I am just pressing the clutch switch with my hand, will bypass it later.
Only thing I can think of is if my wiretaps didn't make solid connections. I did undo and redo some to verify there where connecting.
Currently I am simulating the system:
I have the system ground connected to ground.
On the 13 wire connection, I only need the Brake switch, park brake, and door input for now.
I also attempted the reservation mode to no avail.
MANUAL TRANSMISSION INSTALL MANUAL SYSTEM PROGRAMMING - Menu 1
RESERVATION MODE
Manual transmission remote starters must be set into Reservation Mode before the remote starter will activate. The activation type of Reservation Mode is determined when the system is installed.
Auto Reservation Mode (Default) 1- While the vehicle is running, place into neutral and apply the park brake.
2*- Press and release the brake pedal twice. The park lights will flash twice, the SIREN or HORN (opt.) will chirp twice and the doors will unlock (opt.). 3-Turn the ignition key off and the vehicle will continue running. 4**- Within 30 seconds, exit the vehicle and close all the doors. The vehicle will then shut off .
Manual Reservation Mode (Optional) 1- While the vehicle is running with the key, place transmission into neutral
and apply the park brake. 2- Press and release the START button. The park lights will flash twice, the SIREN or HORN (opt.) will chirp twice and the doors will unlock (opt.). 3- Turn the ignition key off and the vehicle will continue running. 4- Exit the vehicle and close all the doors. 5**- Press and hold the START button for 3 seconds, the vehicle will then shut off.
* If the park lights do not flash and stay on or the SIREN (HORN optional) chirps a third time, repeat Step 2. ** If the vehicle has dome light delay, the vehicle may stay running until the dome light turns off. This is normally no longer than 30 seconds.
**TEST RESERVATION MODE**
1) Press the start button on the remote without setting the Reservation Mode. The park lights should flash 4 times without starting the vehicle. If the vehicle starts THE WRONG REMOTE STARTER HAS BEEN INSTALLED!!!
2) Set the Reservation Mode then remote start the vehicle. Shut off with the remote wait 10 seconds then open the passenger door. Press Start on the remote and Reservation Mode should be cancelled. (4 flashes) if not, check for proper door pin connections.
*****FOR SAFETY REASONS ALL DOOR PINS INCLUDING THE REAR HATCH MUST BE CONNECTED.******
Any ideas?
Old 04-08-2011, 11:41 PM   #119
What does it do or not do?
Old 04-09-2011, 11:17 PM   #120
bad_bwoy007
Well I just spend 2 hours outside verifying some connections.
I am grounding the park brake connection for now and connecting the negative door input (when opened) to 12 volts to simulate doors closed.
Hood pin switch is not connect to anything and it's reading positive voltage so that is good.
For now i'm just pushing the clutch with my foot.
When i push the start button the park lights just flash 4 times. I tried to enter reservation mode but nothing happened after i pushed the brake pedal twice.
I checked the brake connection and it does read 12 volts into the unit so that connection is good.
All wires are still connected to the starter, acc, & ign as listed above.
Old 04-09-2011, 11:44 PM   #121
4 flashes means that it is not in reservation mode. Are you doing the procedure on page 29 to arm the starting?
Old 04-09-2011, 11:46 PM   #122
bad_bwoy007
Yes, I tried Auto reservation and when i pressed the brake pedal the lights did not flash.
I repeated again and got nothing.
Old 04-09-2011, 11:50 PM   #123
Maybe it needs to see the transition from e-brake off to e-brake on before pressing the brake pedal?
Old 04-10-2011, 12:03 AM   #124
bad_bwoy007
Just tried that too, meaning disconnect from ground then reconnect. Still no luck.
Old 04-10-2011, 12:26 AM   #125
Since it needs to see it running, have you done the tach learning?
Old 04-10-2011, 12:30 AM   #126
bad_bwoy007
Let me go hook that up now.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 02:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 02:26 AM
