how to eliminate tire to fender gap
guys i want to drop my yaris so that the tire tucks in to the fender, how can i do this? tools or parts? thanks
![]() ![]() ![]() ![]() ![]() Drives: 2008 Toyota Yaris Liftback Join Date: Oct 2008
coilovers will get you the most drop (besides air suspension of course), but you can adjust the height as well. and for a flush look you can put on rear hub spacers to flush the wheel with the side of the car.
C-Lift ![]() -------------------------------------------------------------- Current Mods: MI Armrest; Full LED conversion (interior and exterior); RS spoiler; Tinted windows; Tanabe DF210 lowering springs; aftermarket door speakers; 12" RF P3 subwoofer with custom box wrapped in Neffy; seat covers; HID 8000K headlights; HID 3000K foglights; 13mm PG hub spacers; muffler delete with dual tip; eyelids; and.. A little red Domo mascot!
^^ agreed.. coilovers all the way.. im using Megan Race coilovers on mine, currently cant attach photos right now cuz im at work, but here is the link to a picture. mine is the black hatch with the red rota rims.
http://www.yarisworld.com/forums/sho...p?t=51&page=65 im only halfway point on the coilover. i could easily drop another 2 inches if not more.. my side skirts already scrap some speed bumps. i gotta take them slow.. |
![]() ![]() Drives: Yaris SR 1.8 Join Date: Sep 2010
If you put a spacer on the back wheels is there still a decent amount of thread on the wheels studs to screw the nuts on? I don't want my wheels falling off.
this all depends on what type of wheel you have and how many inches/millimeters you are getting as a spacer...
get some open nut lug nuts and tighten them down. but some paint or mark the thread on the inside of one of your lug nut threads where it touches the stud. then take it off and see how much thread you got left.. |
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
If you use wheel spacers, the largest I would go without extended lugs is 7mm. 5mm if you really want to play it safe. Make sure to torque the lug nuts down to proper specs and to check them every week or so. |
Well hello guys im back and now with my yaris lowered here are some pictures i am super happy. should i drop more in the back? opinions thanks. ohh and the method of lowering the car is stock factory springs but being cut
toyota
only downside on coilover is they rust like hell....i guess greasing is frequently might help.
really? cut your springs?
why may i ask?
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
How's the ride with cut springs? ...and how many coils did you cut?
![]() Drives: Red Join Date: Sep 2009
My Box and Her Egg
Drives: 05' Scion xB / 08' Yaris 3dr Join Date: Sep 2006
Cut springs are really BAD! They don't fit the spring pockets right and can fall out. On top of screwing up the overall spring rate and creating a very stiff ride.
Do yourself and yaris a favor and get the drop you want using the proper springs. As far as using regular wheel spacers... Be sure to get the right length wheel studs and make sure the spacers are hub centric to avoid vibrations. I prefer the hub spacers that bring the hub and brake assembly out as a whole so you don't have to mess with the wheel studs. |
#13 | |
#14 |
I bet you look funny bouncing on the road. ;)
#15 |
I don't understand why everyone thinks cut spring are going to make the car bouncy? Is it just the stereotypical thinking of Honda Civics riding on bump stops? Because your shocks and struts are going to determine that, unless of course you go overboard and are riding the bump stops.
#16 |
Pirate Yaaaaris
Drives: '00 Toyota Celica GTS 6MT Join Date: Aug 2009
^ Four inches off the front stock springs while maintaining the softness of stock struts is going to be pretty damn close to riding the bumpstops all the fucking time.
There's no way the OP will convince me this is healthier for the car than using proper lowering springs. Cheaper? Maybe, until clicking CV axles and blown struts start showing up. The roads in Miami aren't exactly glass smooth. But to each his own. -C
Georgia Bulldogs! ![]() '09 Yaris LB 5MT Sold. |
#17 |
My Box and Her Egg
On some cars they have springs that narrow down and if you cut them the springs do not fit where they are suppossed to go.
Just because you can cut your springs doesn't make it safe or right. Your car, do what you want if you can't afford to do it right. It's amazing how much ghetto stuff people will do to their cars in order to save a few bucks. |
#18 | |
| Tire rotation: Does TPMS recognize tire position? | jcdrotos | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-17-2011 02:00 PM |
| Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? | St_G | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 03-16-2011 06:29 AM |
| Tire Size and FE question | GMKing | Fuel Economy Forum | 8 | 09-01-2009 09:20 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
