#649 |
ヤリスワールド
Drives: 2008 HB Join Date: May 2010
So sad...thanks for the plead for the 5 axis...
#650 |
Modded Moderator
Yes thank you!
#651 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
#652 |
Got some work to do...
#653 |
and some splainin'!
#654 |
Looks familiar!
#655 |
Now I just have to get it in before the race next weekend.
#656 |
what name brand is that u testing out? u used to ran Kaaz right?
#657 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2007
Government sucks ass!
5% Tint Rear | Micro Image LED Ignition Light Kit |
#658 |
Only two hours to pull the trans this time. :)
#659 |
Yaris video number two, JGR MX, is up:
http://www.jgrmx.com/cgr/community/home.htm http://www.youtube.com/watch?v=I-iTY8DDiuk JGR NASCAR VS MX: http://www.youtube.com/watch?v=5XFi4upCcS8
#660 |
Since the trans came out so easy - clearly I have had too much practice - I decided to tackle another project, a new steering column. The stock column has a lot of resistance, even with the motor removed, and it is very heavy. So it will be replaced with a splined shaft and couple of heim joints.
#661 |
^ ooh curious to see how that turns out.
#662 |
Being able to pull the parts out of the sedan that was getting crushed is making it easier.
I just have to weld up a top mount for the heim joint closest to the steering wheel.
#663 |
ingenuity at its best!
#664 |
If anyone is in the Rosamond, Calif. area this weekend we will be racing the Yaris at Willow Springs. Right now there are seven cars in our class, with about 30 in our group.
Best of all, snow in the forecast for Sat. ![]() Camguard Presents San Diego Cal Club Double Rational Willow Spring International Raceway February 26-27,2011 Sanction #11-N-1384-S/11-N-1385-S/11-R-1386-S/11-R-1387-S Start times are approximate and are provided as a convenience for competitors. It is the competitor's responsibility to know when their group is on track as the sessions may begin earlier of later, depending on circumstances = REGISTRATION HOURS Friday .............3:00 PM to 8:00 PM...........at Track Saturday.........6:30 AM to 11:00 AM.........at Track Sunday...........7:00 AM to 9:00 AM ..........at Track TECH INSPECTION HOURS Saturday.........Open 7:00 AM...................at Track Sunday...........Open 7:00 AM...................at Track Tech stickers will be given out at Registration only to those Drivers with an annual TECH and 2011 helmet sticker. Bring your Log Book & helmet to Registration. All other Drivers must go to the TECH Trailer during scheduled hours. RUN GROUPS NATIONAL/REGIONAL Group 1: SM, PRO7, SPEC 7 Group 2: FA, FB, FC, FE, FM, ASR, CSR, DSR, S2000, CS2000 Group 3: ITA, ITB, ITC, ITS, ITR, SSB, SSC, ST, T1, T2, T3, SPEC 944, HP,STU Group 4: SRF, FF, CF, SF.F500, FV, FS, FST Group 5: GT1, GT2, GT3, SP, GTL, STO, EP FP, ITE, AS, RS, HC, ASC, MAZDA GT2 REVISED 2-6-11 8:00 A.M. Group 1. 20 Minute Practice Followed By: Group 2 20 Minute Practice Group 3 20 Minute Practice Group 4 20 Minute Practice Group 5 20 Minute Practice 10 Min. Break Group 1 20 Minute Qualifying Group 2 20 Minute Qualifying Group 3 20 Minute Qualifying Group 4 20 Minute Qualifying Group 5 20 Minute Qualifying 1 Hour Lunch Group 1 18 Laps Race/or 30 min Group 2 18 Laps Race/ or 30 min 10 Min Break Group 3 18 Laps Race/or 30 min Group 4 18 Laps Race/or 30 min Group 5 18 Laps Race/or 30 min 8:00 A.M. Group 1 20 Minute Practice Followed By: Group 2 20 Minute Practice Group 3 20 Minute Practice Group 4 20 Minute Practice Group 5 20 Minute Practice 10 Min. Break Group 1 20 Minute Qualifying Group 2 20 Minute Qualifying Group 3 20 Minute Qualifying Group 4 20 Minute Qualifying Group 5 20 Minute Qualifying 1 Hour Lunch Group 1 18 Laps Race/or 30 min Group 2 18 Laps Race/or 30 min 10 Min Break Group 3 18 Laps Race/or 30 min Group 4 18 Laps Race/or 30 min Group 5 18 Laps Race/or 30 min
#665 |
![]() ![]() ![]() Drives: yaris1.33 Join Date: Jul 2010
cool video :)
thanks |
#666 |
What a weekend... Freezing temps, burned up tires, contact, great racing.
After the mad thrash to get the OS Giken LSD installed we made it to Willow Springs for the SCCA Double National. Seven cars were registered in H Prod, but only five ran each day. Apparently the threat of nasty weather on Sat kept some of the topless cars away. This was also our first race using the 13" Goodyear slick mounted on our new Jongbloed Racing wheels. This combo drops about 30lbs of unsprung and rotating mass from the car, and the tires are 3" smaller diameter, which really helps the gearing. I got the Pole on Sat, and a great start in the race. The Yaris is a completely different animal with the new diff and tires. No more one-leggin coming off of turns, hit the gas and it just pulls. Unfortunately, as we thought might be the case the much shorter tire is more heat sensitive than the monster 15"s we were running. About midway in the race the front tires started to give up, and as the last few laps were winding down I could hardly keep it on the track. At the stripe Gary Wittman took the win in his Austin Healey Sprite, I held on for second. I killed a brand new tire in one day. ![]() For the Sun race I changed to a harder compound Goodyear on the front of the car. Once again I qualified on the Pole. This turned into one of the best races I have had. Wittman and I swapped the lead something like eight times. At about half way Wittman and I entered Turn 1 side by side (a 90 degree left hand sweeper that is taken around 90mph) and made light contact, I got pushed a little wide and put two in the dirt. I kept my foot in it and stayed on him. Luckily the contact was mostly tire to tire, leaving him with a black stripe and me with a yellow sidewall. ![]() ![]() The harder compound tire stood up much better, and only started to fade at the very end - Goodyear still has one harder compound we can try next time. It was a very close race but Wittman had just a little more left than me at the end, after a 30 min race we were just over 1 sec apart at the finish, with Wittman first and me second. Even though we did not win, we are very happy with the changes to the car, it certainly faster and way more comfortable to drive at the limit. This makes four poles, two wins and two seconds so far, and we are leading the Divisional points again. This event marked the one year anniversary since our Yaris hit the track. In 2010 we lapped Willow Springs at a 1:41.7, now a 1:36.9. Progress.
| Hood Stay (lift) Instal | 1NZYaris1 | DIY / Maintenance / Service | 31 | 09-22-2016 07:56 PM |
| The opposite sex can't stay away with ssk | POORSHA | DIY / Maintenance / Service | 20 | 08-19-2009 10:41 AM |
| eTiMaGo Stay safe | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 20 | 12-02-2008 05:31 PM |
| Tuned a DBW Toyota yesterday | Turbo&Auto | Performance Modifications | 17 | 08-17-2007 12:04 AM |
| why am I always here?! wtf...i cant stay away.. | Blenjar | Off-topic / Other Cars / Everything else Discussions | 5 | 02-26-2007 10:51 AM |
