Old 03-17-2011, 12:23 AM   #1
yaris2010RS
yaris2010RS's Avatar
hey...if the issue is the connector cant u cut them off and hard wire them together?
Old 03-17-2011, 01:20 AM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thumbs up
Yes it could be done, I would like hear TCScott's opinion first.
Once I pulled too hard and I end up with 2 single wires in my hand, put them back in and it was ok. I was ready to cut and solder the wires my self.
D.
CLA 250, 4MATIC
Old 07-28-2011, 10:34 AM   #3
Duncan Ashworth
Drives: 2007 Toyota Yaris
Unsafe 07 Yaris
Total cost spent to date related to the faulty ABS brake issue is $6000+- and counting. Sooner or later Toyota Canada has to issue a recall notice for this major safety defect. I'm amazed no one has been killed yet! We have spun around 3 times because of a locked rear wheel. Wow! unbelievable. I recently filed with Transport Canada. I will be undertaking legal action unless Toyota Canada fesses up.
Duncan Ashworth is offline   Reply With Quote
Old 07-29-2011, 03:43 PM   #4
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Good luck with Transport Canada - I filed almost a year ago and got no response.
My ABS lights have been on for a couple of years now ... I don't really care to spend $$$ to fix this.
If you find a way to solder them directly to the hub without damaging anything, can you please post some pics of what you've done? I would like to do the same and then apply a crap-ton of weather proof silicone to seal the bugger.
devinlamothe is offline   Reply With Quote
Old 07-29-2011, 07:56 PM   #5
"G"
Drives: 2007 Yaris Hatch
In order to solder them directly you need to remove the hub anyway, so you might as well install a new one.
"G" is offline   Reply With Quote
