Old 08-11-2024, 06:58 PM   #1
thetut
Drives: 2007 4dr sedan
Read post #152
thetut is offline   Reply With Quote
Old 08-12-2024, 06:16 AM   #2
BLH
Drives: 2007 Yaris Sedan
It is in post #162
BLH is offline   Reply With Quote
Old 06-01-2025, 10:19 PM   #3
scott10301
Drives: 2007 3dr Hatchback
Just did the install today and no luck. I have a 2007 with no indicator light and want to troubleshoot to see if I'm at least the switch to the ECM is working.
How do I troubleshoot this? I saw that some are mentioning that they're testing voltage while depressing the on/off switch. Are you removing the pin from the D3 connector and then using a multimeter to test? I'm not sure how else that would be done. I did pull the pin and checked and am getting 13.3 volts whether I press the on/off button or not.
scott10301 is offline   Reply With Quote
Old 08-11-2025, 05:20 PM   #4
scott10301
Update - I found the issue. The splice connector under the hood was not set up properly. Set it up correctly and all is working well.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
