Old 02-27-2007, 07:15 PM   #1
St_G
Drives: Black 2007 Yaris Liftback 1.5
I haven't done my speakers yet, but when I spoke to an installer about putting them where Violin did (which looks very nice and nearly stock) he cautioned against it. I think I'm going to go for the A-pillar as well.
St_G is offline   Reply With Quote
Old 02-27-2007, 07:46 PM   #2
Razr
YRS WHOR
Razr's Avatar
Drives: White 2007 Yaris E-Limited 5dr
If possible, I'd recommend trying to get an angled tweeter mount (like the one pictured below) and experimenting a little before going to all that work..
If it does work out, the custom trim panel idea would be sweet.
Razr is offline   Reply With Quote
Old 02-27-2007, 07:58 PM   #3
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The first problem with the tweeters in the arm rest panel...or anywhere in the door panel for that matter is time alignment. Your left ear is MUCH closer to the left tweeter than the right one.
The second problem with the tweeters (depending on the specific behavior of the tweeter) is that the tweeters mounted on the armrest are not facing each other...or facing inwards to promote a proper stereo soundstage. This does depend of the axis response of the driver...still, you'll notice a much weaker response with this setup versus a frontal a-pillar install with the drivers 1 or 2 degrees off center starting to aim outwards towards the hood. Not knowing what specific tweeter we're working with, I'm only speaking generally AND about the Legatia tweeters from Hybrid Audio...and Focal's TN-51 tweeter.
A better stereo image and sounstage will happen if you have these tweets mounted in a kickpod or low in the a-pillar.
IMHO
― Thomas Paine
Old 02-28-2007, 01:07 AM   #4
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
Originally Posted by jdubau55 View Post
Where would be the best place in the rear to install the tweaters from a component set to get the best sound stage? I usally dont have rear occupants so really all I'm worried about is how it sounds to my ears.
If the sound is for you, the only speaker behind your head should be the sub.
earljail is offline   Reply With Quote
Old 02-28-2007, 05:06 AM   #5
Razr
YRS WHOR
Razr's Avatar
Looks a neat install from the pic eTiMaGo - what speakers are you running?
From that pic it seems there's not much of a cavity behind the A-pillar judging by the way they've built it out - I haven't pulled it apart the check yet, but definately interesting to note down, cheers!
Would look nice and stealthy if the tweeter grilles were painted the same light gray..
Bugger, all this talk of audio is making me want to accelerate my plans, but if I do go ahead with it now, it'll put a dent in our Songkran (Thai New Year) holidays :(
Old 02-28-2007, 05:26 AM   #6
Well... From what I see, it lookslike they basically reupholstered the A-pillar so as to cover the construction of the tweeter cup, I don't remember what the stock A-pillar looks like though
Songkran... much better to stay in and mod than get out and get drenched And it's madness up in Chiangmai, I went there once many years ago... fun!
Old 02-28-2007, 05:41 AM   #7
Razr
YRS WHOR
Razr's Avatar
Will have to pull apart the A-pillar at some stage to see what's behind - I'd really like to flush mount some Alpine SPX-177R tweeters in there, and would prefer to keep the stock trim grains if possible..
Yeah, Songkran in Chiangmai is 9 days of sheer madness*!
I "played" Songkran for 3 of my first 5 years here, but now we just go visit the Mrs' home town instead, where it's a little more sedated.. No probs dealing with the yocals, as the drinking there starts at 4AM, so they're all hammered by midday LOL.
* Chiangmai's Songkran celebrations are in the Guiness book of records as the world's largest water fight, and beleive me they ain't kidding!
Old 02-28-2007, 05:15 AM   #8
Razr
YRS WHOR
Razr's Avatar
NM - just fired up my lazy clicking finger and checked your garage.. Boston S series, nice!
Old 02-28-2007, 06:01 AM   #9
Razr
YRS WHOR
Razr's Avatar
Alright, just pulled apart the A-pillars - by my estimation there's approx. 15-20mm of mounting depth to be had, but the wiring will take up a few mm on it's own of course..
I haven't got the SPX-177R's yet, so have no idea what the depth on the recess cups is - does anyone know?
Old 02-28-2007, 06:40 AM   #10
Fine, fine, I'll go rip out my A pillars later too Just yank them out, right? I am quite curious now as to how they did it...
Old 02-28-2007, 07:04 AM   #11
Razr
YRS WHOR
Razr's Avatar
Yeah - just peel off the rubber strip around the door frame (in the vicinity of the A pillar panel), and ease the A-pillar towards the center of the car - there's only a couple of pop-off clips holding it in place.
Old 02-28-2007, 12:43 PM   #12
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The only drawback of this placement in our vehicles is if you have SRS airbags in those pillars. Can you imagine a tweeter killing someone because it was mounted in the a pillar and got launched at an occupant during a crash?
Kickpod in that instance is probably the most applicable location. I know you're going to have fun if you have a manual transmission.
― Thomas Paine
Old 02-28-2007, 06:05 PM   #13
Razr
YRS WHOR
Razr's Avatar
Good point!
If you look at the pics I took, you can see the flat area where the tweeter could mount is a little rebated/offset from the exploding dash panel. If you could get a flush mounted tweeter using the stock A-pillar I don't think you'd have a problem.
Old 02-28-2007, 04:49 PM   #14
St_G
Etimago, that looks really nice. What's not perfect about it?
Old 02-28-2007, 06:24 PM   #15
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
I think I'm in over my head when it comes to PROPERLY locating and adjusting the tweeters. Im pretty much set on the Alpine type X comps and the Type R coax's in the rear.
jdubau55 is offline   Reply With Quote
Old 02-28-2007, 08:45 PM   #16
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Don't let all the information get to you. If everything else fails, go to the "Standard" kickpod fallback.
― Thomas Paine
Old 02-28-2007, 10:06 PM   #17
jdubau55
Well thats the thing. I want the info to get to me. I have learned tons over the years by asking tons of questions and listening to all the opinions given. Basically, I want to be well educated when it comes time for me to install my front speakers. Rears will be easy since they will be coax, as will the sub since I have decent knowledge about those.
Old 03-01-2007, 01:15 AM   #18
earljail
earljail's Avatar
Etimago, that is **really** clean looking. I also like your cellphone holder.
OP, I thought of another idea for mounting tweeters of a component set. Put the woofers in the usual place in the doors. Make some kind of bracket that crosses the woofer to hold the tweeter, out of wood or metal.
The inside of the door panel speaker grill might need to be trimmed. If you've seen the door panel off the car, you'll know what I mean.
DIY 07 Sedan Rear Speaker install vodkalush DIY / Maintenance / Service 32 10-20-2017 04:40 PM
Can I install these speakers to the front and rear of my liftback? W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 33 02-25-2009 03:23 PM
60/40 rear seat in LB - anyone install one? wilco Cosmetic Modifications (Exterior/Interior) 0 08-20-2006 07:42 PM
