Old 05-04-2011, 07:19 AM   #1
Vinceb
Drives: 2008 5 Speed Sedan
Originally Posted by Klink10 View Post
I could see me in there with a case of Coke going to town. I feel for you brother. Good luck
why do you suggest coke? how is an acid going to neutralize an acid? I have used coke to clean things before, but never a battery. Baking soda and some kind of dielectric grease when it's all clean would have been my suggestion. i'm at almost 3 years on the stock battery, no corrosion issues at all.
Vinceb is offline   Reply With Quote
Old 05-04-2011, 08:23 AM   #2
Klink10
Klink10's Avatar
Read it during a google check on another website. Trust me it worked. It was handy and I didn't want to mix a batch of baking soda when I could pour coke in a bowl and let it sit. Took no time at all followed by a rinse/dry and treat with dialectric grease. The big issue was determining the cause which was a loose neg. battery terminal. I have the screw in types on a non stock battery (pics in the garage).
battery, battery terminal, corrosion, duralast, fail
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Charging voltage for stock battery Vinceb DIY / Maintenance / Service 3 02-12-2011 12:10 AM
Fog lamps as back up low beams. ellenbetty General Yaris / Vitz Discussion 114 10-22-2009 03:40 PM
Installation of a Battery Isolator frostbitten In Car Entertainment + Electronics (audio / video / alarm) 3 10-07-2009 12:11 PM
