#1 | |
#2 | |
![]() Drives: Toyota Yaris 1.33 5D HB Join Date: Aug 2010
But AFAIK in this case, the input signal (voltage level) from either accelerator pedal (hall probes) or DAC would be somehow degradated (lowered) due to voltage drop PN junction.Solid state switching is definitely faster than mechanical relay. But advantage of a relay is that it does not require power supply to interconnect one of the input lines to the ouput. I though of using this a safety mechanism, so in case anything goes wrong I would just switch off the power supply to cruise control module and the relay would (almost immediatelly) switch back to default state (direct connection of accelerator pedal). But if I find some good solution using solid state, I am about to change my mind. |
#3 | |
http://www.kpsec.freeuk.com/trancirc.htm Rather than switching back and forth, it may actually make more sense to put the microcontroller in between the pedal and the ECM. That way, the ECM samples the pedal outputs and then in normal mode, just emulates what it sees. Then, in CC mode it ignores the input and sends its own output. The other advantage of this method is that you can improve the throttle response in normal mode (like the Blitz throttle controller does).
#4 | |
Another idea came to my mind how to avoid switching delays with a relay. If I connect the DAC output directly to output line of the relay (to ECM) and accelerator pedal to one input of the relay (the second input remains unused), I can first set the output voltage on DAC and then switch the relay (cut the accelerator pedal line). On a switch back, the accelerator pedal is switched on first and then DAC disabled. This way, there is no voltage drop on signal line to ECM. The only drawback is, that all time, when DAC is not in use (even just before switching off the accelerator pedal line, when DAC output is set) there is voltage from accelerator pedal to DAC output. I have no idea, if it can harm it in any way and what the impedance between DAC output and ground. If the impedance is too low, it can make a short connection and damage the ECM, that I obviously would like to avoid ![]() And finally, do you have any idea, what size the input impedance of ECM could be? |
#5 | |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 12:59 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 11:12 PM |
