Old 07-26-2011, 12:21 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
CTScott - by any chance are these connectors the Sumitomo MT non-sealed line? http://easternbeaver.com/Main/Elec__...onnectors.html
Scroll to the bottom...
Lil Abner - I don't usually get south of Port Sheldon, but occasionally go out that way for shopping.
Old 07-26-2011, 01:01 PM   #2
Close, but not quite. The male has the tabs in the wrong direction and the female is missing the two tabs.
Old 07-26-2011, 03:38 PM   #3
CrankyOldMan
Are you looking at the ones on the bottom half of the page? The top half (HM series) are very much incorrect, but the bottom half looks like they might fit. The photos on this site are pretty crappy resolution and low contrast, but it's the closest thing I've been able to find so far.
6-pos MT series
10-pos MT series
The polarizing rib channels are both present (the OEM only uses one) but that doesn't matter in this case since they're going into the OEM stereo. The female sockets however won't work on the OEM wire harness unless one of the ribs is removed.
Old 07-26-2011, 03:46 PM   #4
This is what the correct ones look like from the side. Note how the male pin has the ribs on the opposite side and the female has them, but the pins above do not. The pins above may work, but my experience with various other Toyota pins is that even though they look mighty close, they end up not working. Either they won't insert all of the way in, or the pin lock won't snap back into place.
Old 07-26-2011, 04:10 PM   #5
CrankyOldMan
Oh, I see now. I thought you were talking about the housings, not the pins. Crap, now I'm back at square 1 with finding the original manufacturer. I've checked out Molex, Amp/Tyco and Sumitomo. I can't think of anyone else who might have made them aside from Denso themselves, but their website doesn't seem to have any info on just the connectors.
Maybe it's just more worthwhile to stick with the premade harnesses?
Old 07-26-2011, 04:18 PM   #6
Most of the Toyota pins are custom ones by either Sumitomo or Amp. The ones that I use for my Occupant Classification Sensor Bypass Module (which allows one to still have the passenger airbag function when installing aftermarket seats) are made by Sumitomo and are custom. I had to order 20,000 pins and 500 connector shells as a minimum buy directly from Sumitomo, since no one stocks them.
So, the premade harness is your best bet.
Old 07-26-2011, 04:48 PM   #7
CrankyOldMan
Yow! That must be a Toyota thing--all of the connectors on the parts made where I work are commercially available, and therefore through mouser/digikey.
The good news is that I can officially stop searching for those buggers. If I need to put in longer leads I'll definitely give you a PM for some pins.
Part Number(s) for '09 5-door LB engine air filter? IsLNdbOi DIY / Maintenance / Service 5 01-02-2011 01:51 PM
2008 OEM S model Liftback Lip kit Part numbers PETERPOOP Cosmetic Modifications (Exterior/Interior) 17 07-26-2010 01:33 PM
need part numbers please help?! kid chino General Yaris / Vitz Discussion 5 10-27-2009 02:27 AM
Rubber weatherstripping part numbers The Spectacle Cosmetic Modifications (Exterior/Interior) 6 05-13-2009 06:40 PM
Help Finding part numbers PLZZZZ!!! Duckywitbigfeetz Cosmetic Modifications (Exterior/Interior) 0 07-29-2006 02:21 AM
