#19 | |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
check ur engine mounts and see how much the engine moves at idle and when shifting from drive to reverse. also check the air box (mine came loose and was making a scary sound) and check hoses for contact points (probably against the firewall) and check exhaust bushings
#20 | |
Drives: 07 yaris sedan Join Date: Dec 2010
Air box - maybe. Mine actually broke and was vibrating into itself. A new SRI fixed that. But I could hear that noise constantly pretty much, and didn't have to sound proof my garage and then hold my breath to hear it... Seriously though if its something that quiet its probably a zip tie vibrating with the engine and hitting a coolant line or something even less dangerous... |
#21 | |
but just keep looking for something vibriating and hitting something else.
#22 |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Any chance you could record the noise on your cell phone and then post it as a link?
No clue how its done but i have seen it done.. Any chance of it being part of the exhaust system doing some knocking when you come to an idle, i'd definitely give the whole system a shake as something may have come loose. |
#23 |
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
lol i have this exact same problem. If you have the stock air box in place, check to see if that little snorkel is hitting the frame next to the radiator. I took off the snorkel and I haven't heard that sound again. Just a suggestion - better something cheap and stupid rather than something big and expensive.
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
#24 | |
1.5 or 2.5 both=0-60 in 8
Same problem
#25 |
Drives: 2008 Yaris Join Date: Aug 2011
whining noise turned knocking
Hi, I have an 08 Y and everything has been great up until about 10 days ago. I noticed a "high pitch" zing type noise, sort of random.. whether in Gear, Neutral, Reverse, etc. Now it has gone to a steady knocking, and yesterday for the first time, I could feel the knocking in the shifter. I have an appt with my Dealer,... who thought it might be the Alternator or Water Pump? I have been reading about the Alternator.. and doesn't seem at all what it is.... and the Water Pump.... I don't think so either (but what do I know) lol
Anyways... let the GONG begin |
#26 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
My wife's 05 corolla has made a similar noise since shortly after new. It hasn't changed in the last 150,000 miles.
#27 | |
If the noise goes away its one of those components gone bad. |
#28 | |
| Tags |
| bearing, idle, knock, main, yaris |
