![]() Drives: Charcoal '08 sedan Join Date: Sep 2011
Help for a newb
I'm in the process of going from completely manual to power locks. My question is if my car has none of the lock/unlock wire in the 20 pin connector, do I need to tap in there or can I just run the wires straight from the power lock "brain" to the actuators?
Thanks. |
#2 | |
Thanks for the quick response. I'm sure I'll have more questions along the way but for now I got the extra wiring at Autozone and should be ready for an afternoon of fun
And back with more questions...
Okay, I've hit my first wall. I'm using the Black Widow 852 kit by the way in case it needs referenced. Install manual here (http://www.blackwidowsecurity.com/in...%20Install.pdf).
I'm not trying anything fancy, just running the wires straight to the actuators that came with the kit. I've tried connecting the common unlock wire (black/green) on the brain to the green wire on the actuator and the common lock wire (blue/black) on the brain to the blue wire on the actuator. The brain clicks and the horn honks (once for lock; twice for unlock) but the actuator doesn't move. I've tried every combination of the other two possible lock and unlock wires and even switch blue/green and the actuator won't move. Any ideas? I only hooked up one for now because I wanted to make sure the wiring was right. Do I need to hook up the other three for them to work? Thanks. |
#5 | |
Well I just found out that what I thought was a 12v on the fuse panel was a nothing so I switched the violet/black-violet to one that I think is now 12v. Off to reconnect the brown/brown-black to ground. I'll be right back.
Thanks again. |
Weird. I grounded the brown-black/white-black as per the diagram and then hit the remote and nothing happened. So I checked my 12 volt connections and when I unplugged it and plugged it back in, I now have a long horn honk on either button (unlock/lock) instead of the correct horn honks. Maybe I have to reprograme it now. Either way, it's getting late so the horn probably isn't helping the neighborhood. I'll throw in the towel tonight but man I hope I can figure this out by Thursday (inspection).
Thanks. |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Questions and advice required about power upgrading(windows & locks) | W.A.S.P | DIY / Maintenance / Service | 10 | 07-22-2009 03:59 AM |
| Need Help - Electrical (finding Power) | Ayka | DIY / Maintenance / Service | 7 | 10-12-2006 12:51 PM |
| The power upgrade thread | ChinoCharles | DIY / Maintenance / Service | 19 | 09-27-2006 04:14 PM |
| Custom Sub Enclosure (inc sub, power cap, amp) | wado | Items for Sale by private party | 3 | 09-18-2006 12:53 PM |
