#1 | |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
You can clean the throttle body (If it is dirty) without doing an injector flush, and add a "fuel system cleaner" to your next tank of gas or two. That will cost you $75 and do a good job cleaning up any dirt that is in your injectors. That is what I would do. Also, a brake flush is a good idea, but if it's only a 2009, it really doesn't need to be done yet. I would wait another year or two on that one
05' Echo Hatch - Greddy Supercharger - rear disc |
Italian Tune-up
Get out into the country and go WOT for a bit.
I don't know what your driving habits are, but addressable carbon buildup on an '09 dosen't seem right. I've never addressed it, and my tb is sparkling after 5 yrs/150,000km.
![]() Drives: red 5 door aotomatic Join Date: Sep 2011
I use seafoam in the tank of our fleet trks,for 100,000 mile intake and thbdy clean,i use the spray type seafoam and wear saftey glasses,remove the airbox and ductwork and engine off,hold open throttle and spray inside and all arround in the throttlebody,let soak,if real bad use a old toothbrush and scrub,put all back together,might have to apply throttle to start and rev up a cupple times to clean out.should run much better,seafoam has 3 type,spray,liquid,transtune,all about $6-7 at napa and most auto parts store,can also be used as a fuel stabilizer for storage,hope this helps ya.
#4 | |
Drives: 2011 Yaris 4 Dr. Sedan Join Date: Sep 2011
Unless you are chasing a problem like rough running, rough idle or heavy fuel consumption, I would not spend money on fuel injection flush and throttle body cleaning. You are not causing any harm and can have it done if any problems will develop in the future. Using Chevron gas with Techron if available in your part of the world is all you need. Yes the throttle body does get dirty and can be cleaned without fuel injection flush. (If you are told differently I would look for someone else to service your car). One service I would consider doing is Mass Airflow Sensor cleaning described here http://www.yarisclubuk.com/index.php...nsor-cleaning/ . Again not necessary if there is no problems. Dropping the pan on the transmission and changing filter and topping the oil is a good idea. All the material from polished clutch plates and metal from wear in planetary gears and other moving parts, lessens the oil flow through the filter. I would do this only once, likely at your mileage and then you should be good for life of the car. I would also want to be present when the pan is dropped and take a photo of the debris in the pan as the oil is slowly poured out from the pan. Many times you may find a little pieces of metal, which are flushed out from valve body and are left in there from manufacturing. Then some crooked guy may tell you that your transmission is worn and try to sell you a rebuild job. If this happens, tell him/her to proceed with the job and post the photo. Good luck.
Ratz --------------------------------------------------- Cleverly disguised as a responsible adult.
![]() Drives: Yaris Sedan 2009 Automatic Join Date: Oct 2011
Thanks for all your comments, i do appreciate it. I will go to look for Chevron Techron or BG44K to see if i can find it. I find that it is consuming more fuel than usual, i would say a 15% to 30 % drop i think.
#6 | |
One more thing, you are not in the hurry, ask about, take your time, do a research on the internet, do not take anybody’s word for anything. There is lot of honest good people around, but even they make UN-intentional mistakes. Like president Nixon said “Trust but verify". But that is another story. ![]() *
![]() ![]() ![]() Drives: 2008 5 Door Liftback Auto Join Date: Oct 2011
^ in that case throttle body and MAF cleaning for sure. In my experience even a bit of buildup in the tb hurts mileage noticeably.
You can clean MAF yourself, very easy. Throttle body is easy too, but not as easy.
1999 Honda Prelude Base 5 speed (summer driver) 2008 5 Door Liftback Auto |
| Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 327 | 01-02-2026 11:44 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Carbon offsetting with TerraPass | BailOut | General Yaris / Vitz Discussion | 14 | 05-28-2007 12:29 AM |
