Old 03-23-2007, 11:10 PM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
Originally Posted by Lillydot View Post
so, i should shift to the third gear and then coast? is this safe to do in the middle of driving?
That's correct, and it's perfectly safe as long as you're not going so fast that your engine will red-line when you go into 3rd. I'd say anything up to 55 MPH should be fine.
- Brian
Share the Road
Old 03-23-2007, 12:03 AM   #2
I've been doing a bit more experimenting with this, it's a bit hard to keep an eye on the road, the RPMs and the AFR needle at the same time, but it seems the fuel cuts back in once the revs drop below 900-1000RPMs, at least in 2nd and 3rd gear.
It's still hard to resist the subconscious impulse of pressing down the clutch when slowing down
Old 03-25-2007, 12:10 AM   #3
Basscat
Basscat's Avatar
Drives: 2007 Yaris S Sedan
I'd have to say it works! Just keeping the technique in mind during my normal driving, on my most recent fillup I got 42.9 MPG, compared to a previous best of 41 and an average of about 38-39. Nothing scientific about my observations, but I'm convinced. I do live in hilly country, which probably makes more of a difference. Thanks for the tip!
Basscat is offline   Reply With Quote
Old 03-25-2007, 12:10 PM   #4
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
The only mod I have made to my Yaris so far ... I used 2.5oz. of Lucas Fuel Treatment at my second fueling.
My efficiency on that tank was 43.67 MPG.
I totally agree with the use of the DFCO, it also saves the brakes. whenever it's possible put the engine in compression, the car will also be more stable when braking.
About that Lucas treatement, not sure what it does, but one time a mechanic put a bottle of a strong injector cleaner into my civic gas tank, that increased dramatically the mileage, something like 25% more on the highway. now that it's good but it comes with a cost
hystria is offline   Reply With Quote
Old 03-25-2007, 12:56 PM   #5
BMGYaris
Drives: Yaris 3dr Hatchback
SO WAIt? us AT should never switch it into third over about 55mph?
BMGYaris is offline   Reply With Quote
Old 03-26-2007, 09:26 PM   #6
BailOut
BailOut's Avatar
We're not speaking about the passing gear you can invoke by pressing down a bit on the accelerator while in overdrive, but manually selecting "3" on the shift tree.
I'm not positive about 55 MPH as a hard limit but your owner's manual will have the definitive information. Also remember that we're speaking about dropping into "3" for a deceleration effect, meaning it will place a lot of load on the engine that wasn't there just a second before, wile accelerating past 55 MPH in "3" would have built RPM gradually.
This is why I say that 55 MPH is a good cut-off point.
- Brian
Share the Road
Old 03-29-2007, 03:40 PM   #7
daq421
MPG is the new cool
daq421's Avatar
Drives: 07 Yaris sedan (silver) Auto
Send a message via AIM to daq421
Does this work on both the manual and automatic transmissions (MT and AT)?
Yes, but it is much more efficient with the MT. The MT can achieve DFCO in any gear as long as the clutch is disengaged (meaning you don't have it pushed in) and your foot is not touching the throttle, while the AT can only achieve DFCO with a gear selection lower than D (overDrive), i.e. 3 or L.
Help me understand this.. I should begin using the 3 - L positions on my A/T Yaris to slow down? This is how to activate the DFCO?
-Peter
daq421 is offline   Reply With Quote
Old 03-29-2007, 05:02 PM   #8
BailOut
BailOut's Avatar
That's correct, whether slowing down for a stop or just trying to maintain a certain velocity (i.e. on a downhill run).
- Brian
Share the Road
Old 03-29-2007, 05:23 PM   #9
daq421
MPG is the new cool
daq421's Avatar
Hrrm,
So shifting into 3rd (or lower) won't just create engine braking? Or at least just cause higher revs?
Ok I'll try it..
-Peter
Old 04-07-2007, 10:09 PM   #10
BailOut
BailOut's Avatar
The original post has been updated with solid timing data as well as info on DFCO with a ScanGauge II.
- Brian
Share the Road
Old 04-07-2007, 10:15 PM   #11
AustinYaris
Drives: 2007 Yaris LB Manual
I still don't understand how this is more fuel efficient than just coasting in neutral.
AustinYaris is offline   Reply With Quote
Old 04-07-2007, 10:29 PM   #12
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
If I understand it right....idling in neutral still has gas going to the engine (small amount but enough to keep it running), while this totally cuts gas off to the engine during this period (nada/none even while the engine is rotating).....correct???
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 04-07-2007, 10:34 PM   #13
AustinYaris
I think that's the idea... but regardless... say you're coasting in neutral at 40mph down a gradual incline, you'll maintain that 40mph for much longer in neutral coasting than in 3rd gear. Right?
I would imagine that in 3rd gear... you would come to a slowdown much more quickly having to use more gas.
Old 04-07-2007, 10:43 PM   #14
BailOut
BailOut's Avatar
AustinYaris,
churp hit it dead on. As for costing in N vs. 3 I don't know if you have the AT or MT but with my 5MT I can maintain my speed in a 5th gear DFCO on as little as a 2% grade.
Part of taking advantage of DFCO is selecting the right gear for the scenario. As I've mentioned a few times before this is where the MT really outshines the AT but the AT is by no means unusable for this.
- Brian
Share the Road
Old 04-07-2007, 10:54 PM   #15
AustinYaris
AustinYaris,
Ah... I see where I was confused... the 3rd gear thing really only applies to AT... I actually have a MT.... So you can use DFCO in the other gears... For some stupid reason, I thought DFCO would work only in 3rd gear regardless of MT or AT. Anyways.. I just got my Scangauge II today. I'll have to try out this DFCO. I'll post my results in a few days.
Old 04-08-2007, 11:02 AM   #16
esquiva
Noypi ako!
esquiva's Avatar
Drives: 07 S Sedan 5-Speed M/T
hmmmm...i've been doing this ever since...of course to save gas..i know im not using gas coz im not hitting the gas pedal..
....very good information
Nagka-anak sina boy at nene, isang lalaki at isang babae. binata't dalaga na sila...
Nene jr.: tay, peram naman ng kotse o...
Boy Bastos: sige pero isang kondisyon. mag-ano muna tayo.
Nene jr.: tay meron ako ngayon e. blowjob na lang kita.
Boy bastos: o sige.
pagkatapos ng blowjob...
Nene jr.: tay, bat lasang tae yung etits nyo?
Boy bastos: ah ganon ba? hiniram kasi ng kuya
mo kanina yung kotse e!
esquiva is offline   Reply With Quote
Old 04-08-2007, 04:55 PM   #17
Lillydot
Absolutely Red!!!
Lillydot's Avatar
Drives: 07 A/T Yaris Liftback
something else i'm curious about when using this method: when is the best time to switch back to overdrive? do i switch back before i press my brakes? after i've some to a complete stop? before i press the accelerator again? does it even matter?
Lillydot is offline   Reply With Quote
Old 04-08-2007, 08:11 PM   #18
BailOut
BailOut's Avatar
Lillydot,
Don't go back into OD until you reach a complete stop or are ready to accelerate again. That way you're sure to get the maximum benefit of a DFCO.
- Brian
Share the Road
low gas mileage? yrsdrgn General Yaris / Vitz Discussion 30 01-17-2019 04:26 AM
Synthetic oil MPG boost since change Yaris Dick General Yaris / Vitz Discussion 29 09-15-2007 09:15 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 11:49 AM
MPG trackers acrbill General Yaris / Vitz Discussion 11 01-01-2007 08:34 PM
