Half a Bubble Off Plumb
DFCO doesn't make a noise, and it doesn't rev the engine or downshift an automatic transmission. There's just a sudden slight deceleration as the idle fuel is cut off. You have to be paying close attention to feel it.
There is a separate function in the ECU that downshifts the transmission if you're coasting downhill and apply the brakes. It increases the "engine braking" so you don't have to use the brakes as much. Touch the gas pedal and let it off, and it'll upshift to high gear and let you pick up speed coasting. |
![]() Drives: 2009 Yaris LB Join Date: Dec 2009
Ah you're right, it must be the engine braking. is that bad for gas mileage?
I still don't understand DFCO.. if it's seamless and you don't have to do anything, then how do you do what you said in the instructions?
"As soon as you hit an exit ramp off of the highway go into DFCO all the way to the end of the ramp." By doing what? Driving like you would normally? |
Exactly. Lift your foot off of the gas.
#5 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
if the conditions are correct for DFCO, it will kick in. it will not kick in if you shift to neutral or have any gas pedal input it really doesn't matter a ton for real world, single use... other than reduce emissions a little bit, and improve mileage a very little bit. but over the life of the car x how many cars have DFCO, it matters a lot...the end user doesn't need to know squat about it, it is computer controlled. the end user can induce DFCO conditions more often than 'natural driving' would by adjusting how they use the kinetic energy of the vehicle, and the gas pedal and gear choices. |
Only Happy When it Rains
it can improve gas mileage a lot if you plan to use it.
Colin Chapman disciple |
Keeping your foot off the gas usually does.
#8 | |
![]() Drives: Yaris 1,3 -01 Linea Luna Join Date: Feb 2010
I just read ecomodder 100+ Tips for better fuel efficiency and I saw this:
#9 | |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
There are times and places for both techniques. If you only have a short distance to worry about, or you are going downhill, or you know you are likely going to stop then DFCO is best as it allows you to decelerate without fuel usage. But if you would rather maintain more of your speed over a longer distance then coasting in neutral is better as it takes much less fuel to idle for a short while than it does to re-accelerate from a major momentum loss.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
Drives: Toyota Yaris 2007 3 Door Black Join Date: Mar 2010
It's a good read, and I'll definitely pay more attention to how the car performs.
BTW, New guy here. Congrats on the sweet community you guys have made and I'm glad to add myself to it, I've already read tons of great tips.
Forget the Dog, Beware of Yaris Owner. |
![]() ![]() Drives: 2010 Yaris 3-door liftback Join Date: Mar 2010
So . . . on the MT, avoid downshifting?
![]() 2010 3-door 5-speed, Meteorite Metallic |
What?
Downshift when you need to when cruising or accelerating. (like if you don't have enough power to get up a hill in the gear you're in)
Delay downshifting on deceleration to prolong your DFCO coast. (downshifting earlier gives you more engine braking, which you don't want if you're trying to coast as long as possible "for free") |
Alrighty! Thanks!
Oh, and I'm assuming that my goal is to stay around 2000 rpms, right? I.e., upshift before it gets TOO far beyond that?
High RPMs don't hurt much when you're in DFCO. I routinely go a little above 4k RPM while in DFCO in the mountains.
#15 | |
What?
![]() If you're decelerating/coasting in DFCO, simply don't bother to downshift unless your revs get below 1500. My typical DFCO maneuver is to just stay in 5th to about 2k or so (I don't really look at the tach), and then skip 4th and downshift to 3rd for the majority of a decel. If I can stretch it further (the light ahead of me is red, or traffic isn't moving), I might grab 2nd and try to maintain enough momentum to stay in 2nd and never have to stop or downshift to 1st if I can avoid it. The short version of that is: Always coast for as long as possible in DFCO, and always try to time your position within traffic to maintain as much momentum as you can and avoid slowing/stopping unnecessarily. |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
DFCO is not some exotic new feature. It's been a standard feature of most FI systems for at least 20 years. Many of the electronic feedback carbs of the 80s had it. What *has* changed is that its implementation has gotten more aggressive over the years. On my carbureted 1988 Chevy Sprint Metro, it doesn't kick in unless the engine is above 2500 rpm (about 56 mph in 5th) whereas, apparently, 1100 rpm is sufficient on the Yaris.
Also, it is not some magic feature that you can "use" to get better fuel economy. It does one simple thing: When conditions require *less* power than that produced by the 0.2 gal/hour that the Yaris engine consumes at idle, it eliminates that tiny bit of consumption. If that power is needed, e.g. to keep the engine idling, or even to maintain your desired speed when descending a hill, then the fuel is duly provided, and should not be considered to be any sort of waste. |
Audio Junky
seemed pretty magic to me, i instantly saw a 10% (4mpg) increase in mpg's after I started using it.
#18 | |
Reality check: Consider that if you manage to stay in DFCO mode for a full hour, you've only saved about 0.2 gallons of fuel (specifically due to DFCO) since the Yaris' engine uses about 0.2 gal/hr at idle. To get a 10% improvement in fuel economy over the course of a tank of gas, you would have to spend over 5.5 extra *hours* in DFCO mode. Do you think that you are managing that much? -Steve Bergman Last edited by sbergman27; 03-10-2010 at 12:42 AM. |
| low gas mileage? | yrsdrgn | General Yaris / Vitz Discussion | 30 | 01-17-2019 04:26 AM |
| Synthetic oil MPG boost since change | Yaris Dick | General Yaris / Vitz Discussion | 29 | 09-15-2007 09:15 PM |
| Increased MPG or HP anyone???? | slvryaris | Performance Modifications | 55 | 05-27-2007 11:49 AM |
| MPG trackers | acrbill | General Yaris / Vitz Discussion | 11 | 01-01-2007 08:34 PM |
