Old 11-09-2011, 09:21 PM   #6
white_rice
white_rice's Avatar
Drives: 2008 Toyota Yaris LE
Send a message via MSN to white_rice
So believe it or not I just finally got around to fixing it this week! LOL Took apart the surround around the temp controls to find that the one piece simply wasn't snapped in that held the pin to control the dial. I'm guessing it was probably in an IA condition from the factory and just let loose finally after use/vibration. As once I seated it entirely I don't see how it would come out without good pressure on the tabs.
Nonetheless that problem is fixed. However in doing so, I noticed later in the evening (once dark) that now the top and bottom of the 3 temp dials are no longer illuminated. I took it apart quick again and all the wires are still in tact and what not. Possibly the bulbs blew from dis and re-assembly? I didn't see anything blaintly obvious anyways. It would appear at first glance the dials need to be dissambled to get to the lights within the dials?
Thanks
white_rice is offline   Reply With Quote
