Old 04-05-2017, 01:49 PM   #1
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
The switch in question replaces the pedal up stop bolt. Look where the clutch pedal sits when you're not pressing it.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 04-20-2017, 04:53 PM   #2
Eduardo_mty
can i use this https://www.aliexpress.com/item/High...e-b2f5a6af3066
Eduardo_mty is offline   Reply With Quote
Old 08-01-2017, 07:28 PM   #3
laobo
Drives: yaris sedan 2011
Dear Friends!
Tell me known yaris sedan 2011with 1.3 /2NZFE engine, also Yaris sedan 2014 with 1.5 engine can be to installed CCS ? Thanks a lot!
laobo is offline   Reply With Quote
Old 08-08-2017, 01:30 AM   #4
laobo
Dear CTScott.
I m looking for pin ccs from ECM for vios\yaris sedan 2014-2015. Tell me pls
Old 11-09-2017, 02:00 PM   #5
HDTechVideo
Drives: Yaris MK3 1.33L Dual VVT-i CVT
Hi I have yaris 2013 multidrive. Is it possible to add cruise control on it?
Sent from my SM-G935F using Tapatalk
HDTechVideo is offline   Reply With Quote
Old 11-14-2017, 08:49 AM   #6
HDTechVideo
Installed cruise control and its working perfect. Along with cruise controlinstalled speed limitter but dont think that is working, may be im doing it wrong.
Old 11-15-2017, 07:31 AM   #7
bilucci
Drives: YARIS TOUCH
Hi guys,
this is my first post inhere
I just fit the cc switch to my french made Yaris 2012 NSP130L 1.33L gasoline with 1NR-FE engine and 6 manual transmission, but the cruise light won't come on when switched ON.
has the radio touch system with the bluetooth call buttons on the right of the steering wheel aswell.
any advices please ?
bilucci is offline   Reply With Quote
Old 04-22-2018, 07:59 PM   #8
laobo
Not need light on when ccs work.
Originally Posted by bilucci View Post
Hi guys,
Show me ccs diagram connect for Manual transmission .( pin of ECm, clutch pedal..
Old 06-03-2018, 05:48 PM   #9
Captain Yaris
Captain Yaris's Avatar
Drives: 2016 Yaris 3 Dr Super White
I have a US 2016 Yaris L. I popped the airbag off and to my suprise, no wire to connect to the switch and no screws to secure the switch. Do any of you know what the deal is? I thought these things are prewired for cruise control. Also does amyone know the screw size to secure the switch? Thanks!
File Type: jpeg DA86DBDC-C063-44B6-AC9D-38D0A6B31C15.jpeg (179.3 KB, 323 views)
File Type: jpeg 1C8D15E2-DD38-40E1-AE70-1A8113ECB7F0.jpeg (182.2 KB, 316 views)
File Type: jpeg 8FB68596-F555-46A8-B283-53625D316DC5.jpeg (220.2 KB, 318 views)
Captain Yaris is offline   Reply With Quote
Old 06-03-2018, 07:46 PM   #10
DarkShadowFox
gimme a minute.
yeah im not finding a diagram on my GSIC
looks like a trade secret thing. just like how the lane departure etc have no diagrams online for spare parts.
Old 06-03-2018, 09:09 PM   #11
Captain Yaris
Thanks for checking. Hopefully someone will have knowledge of my situation.
Old 11-19-2017, 11:59 AM   #12
HDTechVideo
Installed cruise control stalk and it is working perfect. Along with that installed ASL switch in the steering wheel. But it is not working. Checked the connection in the back side of steering wheel and found a light green cable is there and both from ASL and this one are connected eachother (verified using multimeter).
Old 03-28-2018, 05:21 PM   #13
AndreS123
Drives: 2012 Yaris L, 2017 Yaris L
i just picked up a 2017 Yaris L, US model made in France, need to add cruise.
AndreS123 is offline   Reply With Quote
Old 03-28-2018, 08:25 PM   #14
Captain Yaris
I am also trying to add cruise control to my 2016 L. I am just about ready to order the parts. I have a manual so I need another switchbfor the clutch pedal. The parts I ordered and am going to install are:
1) On/Off Switch/Stalk - 84632-08021
2) Clutch Switch - 88280-42010 (For a manual transmission)
3) Stalk Cover - 45186-0D150-C0
I found a decent price online at parts.conicellitoyotaofconshohocken.com. I plan on adding fog lamps later on and I only want to take off my steering wheel cover and airbag once so I am also ordering the headlamp switch which is: 84140-47161. Let me know how it goes for you. I’m planning on watching youtube to get my bearings on the install before attempting.
Old 04-22-2018, 07:49 PM   #15
laobo
Dear. If you have diagram connection ccs for manual transmit yaris 2016-2017. Share p
Dear. If you have diagram connection ccs for manual transmit yaris 2016-2017. Share please
Old 04-08-2018, 12:59 PM   #16
RicStyx
Drives: 2012 Toyota Yaris 1.3 -3rd Gen
Hi all, I too would like to add cruise control to my 2012 1.33 six speed manual French built yaris.
What are the exact toyota part numbers that I will need, and when purchasing the stalk and cover, does it come with the small wiring loom for connecting it. And would anyone be able to tell me if I need the clutch switch for my car.
Also would anyone have a video of them installing it or a link to one?
Thanks.
Sent from my SM-N910F using Tapatalk
RicStyx is offline   Reply With Quote
Old 06-21-2018, 02:50 PM   #17
Captain Yaris
Got it figured out, and now it’s alive!!!!!!!!!! I had to swap a wire that was just a plug with a ground with a different wire that included the ground and connection to the cruise control unit. A special thanks to DarkShadowFox for hyperlinking that video of the Rostra install. It gave me the idea to pursue the correct wire from Toyota. Thanks for the help.
Part numbers to install on US Spec 2016 Yaris L are as follows:
Cruise Control Switch (84632-08021)
Clutch Switch; for cars with manual trans. (8820-42010)
Steering Wheel Switch Cover (45186-0D150-C0)
Cruise Switch Wire (84633-02020)
Cruise Control Switch Screws; need 2 of these. (90159-50199)
File Type: jpeg 4AB0BF84-8153-4B63-B522-72276B4A09F7.jpeg (207.3 KB, 366 views)
File Type: jpeg A52410CA-9F2A-4CF7-BB71-48548B662609.jpeg (164.6 KB, 356 views)
Old 06-21-2018, 03:10 PM   #18
DarkShadowFox
LMAO JFC dont tell me even the L gauge cluster has a spot for the cruise control omfg. they are ripping people off on these yarises lmao.
cruise control. 2012
