AKA Samurai Racer
Clutch feel on the TS
hey guys
just a quick question , how does your clutch grab and transition between gears feel ? is it a smooth gear change , or does it bang into gear each time? |
TRIM HUNTER
SMOOTH as silk...
AKA Samurai Racer
ah ok ... then i suppose mine is right ,after i did half the exhaust setup the car use to bang into gear under throttle , meaning i accelerate , the depress the clutch , engage the gear , the release and it kicks you quite hard into the seat as soon as you accelerate ... lately though its doesn't kick as hard into the seat , but the car still pulls well though ... just really weird.
#4 | |
UK Yaris Newbie
Drives: Yaris 1.8 SR Join Date: Jan 2011
#6 | |
AKA Samurai Racer
say you pull away 1st to 2nd , 3rd etc , when i give it some gas , as i depress the clutch , change gear , then release the clutch use to grab quite hard , as you let it go completely it almost kicked you into the seat as you accelerate again. at the moment .. 1st and 2nd feels almost the same but in 3rd when i release the clutch it is very smooth and not clutch kick at all ... any idea's ? is the clutch just worn in nicely ? also under high speed the clutch engagement is totally smooth and clutch kick is felt , good or bad ? before there was more clutch kick .. |
AKA Samurai Racer
any other TS owners wanna add ?
![]() ![]() Drives: sr Join Date: Jul 2011
mine bangs into place as if it suddenly started to work.
not sure if its just me but the 2zrfe engine seems to be very very loose, seems to have too much movement when changing gears, i can feel the engine rock back when ever the loads is taken or apply back onto the drivetrain |
AKA Samurai Racer
mine use to bang in quite hard aswell , but is a little smoother now for some reason , still "kinda" bangs in but it ALOT smoother , not sure if it should be like that or not ?
i know the 2zrfe in the TS has a metal bar connected to the engine and the engine mount to stop it from rocking , maybe the feeling you getting is the clutch engaging hard ? in 4th and 5th the clutch still engages quite hard just really 2nd and 3rd seems soother , not maybe sure if its the cars revs climbing a little smoother cause the engagement to be smoother ? possible ... |
AKA Samurai Racer
what mods do you have on your car ?
now that i think about it , it could have felt smoother in stock form , before i did exhaust and intake ... not 100% sure though |
None at the moment but tomorrow il will be installing a k&n tycoon and d2 coilovers. It maybe my driving style.
AKA Samurai Racer
nice !!! be sure and post the results ;-)
AKA Samurai Racer
you gonna love the intake !
#14 | |
UK Yaris Newbie
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 03:59 AM |
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 07:14 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
