Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 11-20-2011, 01:44 AM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
Originally Posted by 2ZR-FE View Post
TS in the states i doubt it, explain in more detail about your TS mate and I will let you know how i feel about my 2ZR-FE!
ok , here is before
say you pull away 1st to 2nd , 3rd etc , when i give it some gas , as i depress the clutch , change gear , then release the clutch use to grab quite hard , as you let it go completely it almost kicked you into the seat as you accelerate again.
at the moment ..
1st and 2nd feels almost the same but in 3rd when i release the clutch it is very smooth and not clutch kick at all ...
any idea's ?
is the clutch just worn in nicely ?
also under high speed the clutch engagement is totally smooth and clutch kick is felt , good or bad ? before there was more clutch kick ..
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 11-28-2011, 10:12 AM   #2
2ZR-FE
UK Yaris Newbie
Drives: Yaris 1.8 SR
Originally Posted by aucorium View Post
ok , here is before
at the moment ..
any idea's ?
The clutch kicks when changing at high rpm, down low rpm its very smooth though, sometimes it almost jumps into second gear when racing the engine in first! What the hell does that mean lol?
2ZR-FE is offline   Reply With Quote
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
