You can tell if your current ones do by looking at the valve stem. If it is all rubber then they don't. If they have metal where the stem meets the rim, then they do.
My TPWS bypass mod allows an easy method of having a second set of rims without having a second set of sensors. Otherwise, when you swap rims you have to go to a tire place and have them reprogram the TPWS to learn the other set of sensors (our TPWS can only remember one set of four sensors at a time). http://www.yarisworld.com/forums/showthread.php?t=11058
| any tpms swaps out there? steel to aluminum? | severous01 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 03-26-2011 08:10 PM |
| Tire rotation: Does TPMS recognize tire position? | jcdrotos | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-17-2011 03:00 PM |
| DIY - - -TPMS work around | rningonfumes | DIY / Maintenance / Service | 6 | 03-03-2011 09:11 PM |
| tpms compatibility? | bwong2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 07-11-2009 10:33 AM |
| TPMS Gauges - do they exist? | Sodium Duck | DIY / Maintenance / Service | 24 | 03-01-2009 01:18 AM |
