![]() Drives: 2010 Yaris S HB Join Date: Nov 2011
The reason the A/C runs when you turn the defrost on is to dehydrate the air you're blasting at the inside of the windshield. It makes the defroster more effective.
The reason the Prius engineers went to the lengths of putting the thermos bottle in was because the engine doesn't run all the time, and running the PTC (Positive Temperature Coefficient) heater (an electric coil like on a space heater) uses quite a bit of current, and in that car, that reduces the electric-only driving range. |
Huh interesting.
Seeing this thread come up reminded me I havnt posted my findings. Normally the cool engine light goes out on a typical winter morning after about a mile. With the block heater on for about 1 1/2 hours the light goes out after 4 tenths of a mile. Lower temps result in longer CEL outages and higher temps result in shorter one. I figure on an average night in NJ using the block heater results in a 2 mpg gain. Thats for my situation which involves a short drive of ~6.5 miles. Longer drives the result would probably be less....
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 04:07 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 04:34 AM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Change to high quality filter lead to drastic drop in fuel efficiency | lh59 | DIY / Maintenance / Service | 19 | 07-02-2009 03:22 PM |
| Last Fuel Bar | andaconda | Fuel Economy Forum | 37 | 04-29-2009 03:35 PM |
