Originally Posted by Blown_xa
The factory ecu still sees everything and controls the vvti actuator just like factory, this is because of the way mine is wired. The halted sprint 500 doesn't control vvti, so that is how it should be wired. However, with the sport 1000 in your case.... It is wired up and can control vvti. It is no surprise you got gains, but that is because you started at a static vvti state ( you started with zero advance).
And I thought the Sprint series were better than the Sport Series!
