damn...not sure now....cut or no cut..g.rrr n I dont wanna pay 85 bux an hr for that....
I got the TRD spark red spring... any1 got them? bump stop cut off?!?! -- Blen
http://www.360voice.com/tag/noobblenjar ![]() My Car http://www.yarisworld.com/forums/showthread.php?t=4245 My DJ www.PainlessWolf.com |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
Why don't you call TRD and ask them? I am pretty sure I know what they will say.
SPONSORED BY
I agree. Just call them. They are going to tell you that no cutting is necessary with the full TRD setup.
"Hi,
Okay, when installing lowering springs on Struts, you cut the bump stop the same amount that you're lowering the car and in this case I believe that's going to be 1.2" so we're talking about 6/10's of one inch. Talk to you later. Ken" That was Ken from TRDspark, the RED TRD springs. Now all I need to do is get a math major to help me cut this. -- Blen
#5 | |
Lonesome Cowboy
me too, quite surprised, I am still in the air on cutting mine with the new install, i'll probably do a lot of calling around
SPONSORED BY
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
The bumpstops sole purpose is to prevent the strut shaft from hitting its cylinder at the bottom of its stroke (and causing damage)....changing the spring does not change the bottom travel of the strut, so cutting the bumpstop will bring you closer to that destructive interference. There will be some leaway in the design of the strut that you can get away with it sometimes....but cutting the bumpstop doesn't alter the point where damage can be done. Aftermarket struts may be designed to allow for more downtravel, but myself I'd leave it alone with the factory strut. Hitting a rubber stop is much more pleasant than hitting steel to steel!
____________ Old School Cobble Jockey
Of course no cutting is needed with the TRD setup... it was designed to work together..
Now any aftermarket spring and STOCK shock setup will require cutting. Do yourself a favor, call the manufacture of the springs you are buying, AND ASK! Lots of bullshit advice being spread around lately on this topic. |
I cut mine...that first U shape, cut it there...I dunno wat's a buttom out but my ride is fine..looks better..i think it will lower more within the next two weeks.
-- Blen
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
