Old 02-27-2012, 05:05 PM   #55
kou
Drives: 08 lb
Any word on the size of this pipe.
Old 02-27-2012, 05:23 PM   #56
hartley1080
Drives: 2008 Yaris
Just measured the pipe it is 2.25 O.D.
hartley1080 is offline   Reply With Quote
Old 02-27-2012, 05:28 PM   #57
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
ID or OD?
Old 02-27-2012, 08:10 PM   #58
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Wow how about google that shit
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-27-2012, 10:28 PM   #59
1.5
Form>Function
1.5's Avatar
True im looking more for ID.
Old 02-28-2012, 12:10 AM   #60
hartley1080
Drives: 2008 Yaris
Will check the I.D. soon
Old 02-28-2012, 01:22 PM   #61
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
lol http://lmgtfy.com/?q=purchase+hushpower+resonator
Old 02-28-2012, 01:49 PM   #62
1.5
Form>Function
1.5's Avatar
Originally Posted by 47_MasoN_47 View Post
Is that how that website works? I always get so confused when I get there. lol
Old 02-28-2012, 02:37 PM   #63
47_MasoN_47
It can be confusing. So many steps in the process :P
Old 02-28-2012, 02:47 PM   #64
hartley1080
Drives: 2008 Yaris
Thanks for the link
Old 03-06-2012, 11:47 AM   #65
07stlYaris
If Its Not Blown It Sucks
07stlYaris's Avatar
Drives: 07 Yaris LB Meteorite
Running lean. What's up with that?
Just installed this OBX on my 07 LB and now I have a little bit of ping going on. I put one of the 2 Cats back in (after the O2 sensor) and figure that's the problem. Let me know if I should put the other Cat in or move the O2 sensor to after the Cat.???
Since both O2 sensors are basically seeing the same thing now I would guess I'm right with the location thing. just want a second opinion.
07stlYaris is offline   Reply With Quote
Old 03-06-2012, 01:03 PM   #66
Stock location is after the first cat.
So the 2nd cat doesn't matter at all as far as the ECU is concerned.
If you have one cat, the second O2 sensor should be after that.
I'm surprised you aren't getting a CEL with both sensors seeing basically the same thing. Your car should be thinking your cat is not working.
Old 03-06-2012, 01:22 PM   #67
07stlYaris
07stlYaris's Avatar
Got the CEL too, just didn't mention it. I'll be relocating the O2 sensor this weekend when I put in the resonator. Thanks for the quick reply and reaffirmation of my suspicions. Would the ECU lean out the mix because of what the 2nd O2 sensor sees?
Old 03-06-2012, 05:09 PM   #68
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The first sensor isn't an O2 sensor, it's a A/F sensor. The second is indeed an O2 and is only there to read what's coming out of the CAT.
Old 03-06-2012, 06:28 PM   #69
Just keeping it simple. I knew he must be getting a CEL.
Old 03-07-2012, 12:19 PM   #70
07stlYaris
07stlYaris's Avatar
Different parts???
Are they both the same thing just used for different purposes? Are there any other consequences to moving the O2 sensor further downstream? Should I wrap the headpipe to keep the cat warmer? Just trying to get as much info as possible before I get under there one more time.
Old 03-07-2012, 01:17 PM   #71
^ The two sensors are not the same. Technically, the first one is more of an air/fuel sensor (though it's kind of a weird hybrid design by the way the ECU reads the voltages) and the second one is an O2 sensor to monitor the cat. Pretty sure that's all it does.
Why would you move it downstream?
And why would you want it to be "warmer"?
Old 03-07-2012, 01:44 PM   #72
07stlYaris
07stlYaris's Avatar
Downstream past the Cat. Catalytic converters function better at higher temps leading to a more accurate reading for the O2 sensor. Higher temps within reason of course. I've seen melted catalyst in engines that ran waayy too lean. Anyway, thanks for the clarity on the sensors.
Enkei's and Dunlops + Medalion Touring Exhaust 2manywheels Items for Sale by private party 40 04-04-2011 06:01 PM
Rim Weights bosbik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 11-14-2009 07:42 PM
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 03:40 PM
FS: Megan Racing Exhaust n Header. Sabretooth Items for Sale by private party 6 05-17-2009 06:04 PM
12/20/08 Buddy Club USA 5th Anniversary Clearance SALE DuckinOut California 3 12-18-2008 01:25 AM
