Old 03-12-2012, 09:32 PM   #1
NJ Drive
Drives: 2012 Yaris SE
As far as shocks/struts go, there isn't much besides going custom.
One sorta plug-and-play option is to pick up a set of H&R coilovers, fab some stock spring perches, and have them revalved by Bilstein(around $75/corner). The non-adjustability and entry price of them at first glance sucks but I'd imagine it being a solution that is somewhat cost-effective. The total extended lengths have to within +/- 1" of the stockers so that must be checked out.
Part of what I do for a living is force measurement setup, calibrations, etc. so validating the stock SE spring rates are no problem.
I have a set of Intercomp pads that I can use to forward whatever corner weights are present using stock perch heights. I would expect motion ratios in front to be just under 1:1 being a McStrut. As far as torsion beams go, I'm in the dark as far as calculating any kind of usable motion ratios.
Talking base Mini Coopers, yes some have EDLC but like Jason mentioned, on Hoosiers, I'm uncertain if it provides a solid advantage. Fortunately I have some of the best HS competition in and around our region so the measuring stick will be real.
I hate bench racing and just like to go at it.
I'm open for other suggestions regarding shocks/struts.
NJ Drive is offline   Reply With Quote
Old 03-12-2012, 10:02 PM   #2
Jason@SportsCar
AST built ours. I seem to recall Brian saying the rears were easy, typical pin on one end eyelet on the other, there was some reference to an E30 BMW in there - this was a couple of years ago so the details are foggy. The fronts are similar to an MR2 rear.
Old 03-12-2012, 10:37 PM   #3
seth_man
seth_man's Avatar
Drives: 08 Liftback
bmw e46 non-m3 rear shocks are a bolt in for the yaris rear, ive personally been using function form type 2 e46 rears. @ $100 each they are way less expensive that many other alternatives. also '04 -up wrx koni front inserts fit well in stuck strut tubes and megan coilover shock tubes
seth_man is offline   Reply With Quote
Parts of a Yaris compete in SCCA SoloNationals. SailDesign Off-topic / Other Cars / Everything else Discussions 0 09-01-2011 02:50 PM
stock Yaris parts cali yaris Sponsors Classifieds Area 2 08-31-2011 04:26 PM
STOCK SEATS OUT OF HB / stock tires/rims mrrock Items for Sale by private party 19 08-19-2009 05:56 PM
lots of stock parts 2007 yaris h/b and some after market parts laszlo Items for Sale by private party 19 05-17-2009 05:19 PM
Stock Parts for Trade! Yarice Items for Sale by private party 0 04-17-2009 11:23 PM
