#109 |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
I seem to recall this situation with the FIC when our tuner tuned Scions a lot. if I remember correctly, it was one of two things..... The firmware used is not correct, or the FIC unit itself is faulty. I HIGHlY doubt the crank sensor took a crap.
Ptuning.com |
#110 | |
![]() ![]() ![]() Drives: toyota yaris Join Date: Jan 2007
So wat ur saying is the my aem fic is fuked and there is nothing wrong with my crank sensor .. Probably have to send it from where I got it to maybe get it check out I got it as a present friends all put money together and brought it for me
#111 |
^No. What he is suggesting is that it might need a firmware update to a different version, maybe even a previous version. I would certainly try that before deciding the unit itself is toast.
#112 |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
.z107 is the accepted firmware for toyotas / scions.
#113 |
![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
^^^^This
#114 |
alright thanks alot guys i will double check that with the guys !!!
#115 |
okay guys getting my car tomorrow morning.. but not happy
speaking to the guy my o2 oxygen sensors the heating element inside both the o2 sensors keep short circuiting which means when my car is cold it will run crap cause it wont be getting information! They brought me two new ones and after they dyno'd it both sensors heating element have short circuited again! thats my first fuking problem secondly my car will get up 5000rpm and will hit a dead wall! according to the guy he says it a conflict between aem fic and the ecu, could the problem be that the car timing is off at high rpm possibly? Which isnt properly done in the ignition section of the aem? why is it that my yaris has major issues while other yaris members arent seeming to have as bad of issues as i am! i have a feeling that the boomslang i have maybe isnt the same wiring as the yaris in america! he said that the afr on WOT is 12:1 which i still need to install my AFR gauage in anyone give me any input i have no idea wat the fuk is going on!? i dont understand the point of having a boosted yaris if u can even have the full rev range
#116 |
if that is the excpeted fireware i am using currently the F/IC - 6 Patch V3.05
where do u find the z.107???
#117 |
Check the aem forums they have it on there. Don't kno why you are having some many issues. It must be in the tuning somewhere I think. Most of us are running open loop with no o2 sensor.
#118 | ||
RULE #1: Always get back any parts replaced on your car.
#119 |
going tomorrow i will ask him!
#120 |
well tuning is going shit so i probably say tunning is the issue!
#121 |
#122 |
Alright got my car back runs well Only problem is a constant cranksensor mulfaction and both exhaust sensor heat circuit
The 2 oxygen sensors both the heat element inside have broken which where brand new so the car has to warm up the o2 sensor The car still hits a brick wall at 5000rpm but reading aem forums they have see this before I am going to try tonight and fix that problem that's to you guys and aem i think it's the firmware which I hope should fix it more to update! Btw garm I asked for parts and he apparently couldn't find them which is bullshit! He probably has them in the garage!
#123 |
I am looking around for places not many places wana deal with small cars or have no expirence with the aem fic
#124 | |
Ptuning.com |
#125 | |
the maf hasnt been clamped which i was trying to solve how to do it and still unsure??? the aem is using the plug and play harness!
#126 | ||
| List of Boosted Yarisworld Members | whooppee777 | Forced Induction Forum | 262 | 11-23-2022 06:49 AM |
| Boosted Yaris Quarter Mile Times | 1.5 | Forced Induction Forum | 0 | 01-03-2010 06:49 PM |
| Yari Boosted, Enge lite... | N3misiS | Forced Induction Forum | 14 | 11-20-2009 08:22 AM |
| Going Boosted | FryGuy | Forced Induction Forum | 53 | 03-01-2009 11:01 PM |
| PE Boosted Yaris Video | jinxor | Forced Induction Forum | 16 | 02-06-2009 03:33 AM |
