Old 05-24-2012, 10:41 AM   #1
DentGuy
Drives: Supra
Do a compression check to see if you may have bent a rod.
DentGuy is offline   Reply With Quote
Old 05-25-2012, 07:05 AM   #2
djgab101
djgab101's Avatar
Drives: toyota yaris
Hopefully some time soon I can start dismantling and see wat I find!
djgab101 is offline   Reply With Quote
Old 05-25-2012, 08:55 AM   #3
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Yes if your running a turbo the rods are the weak spot. My rod bent on a cooler day when my car was making great power.
pimp my yaris is offline   Reply With Quote
Old 05-25-2012, 08:50 AM   #4
pimp my yaris
C'est la vie
made more progress yesterday, but I ran out of daylight before I could get her wired up.
Old 05-25-2012, 10:48 AM   #5
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
It's looking good. What turbo do u have you eyes on?
Yoda is offline   Reply With Quote
Old 05-25-2012, 10:12 PM   #6
pimp my yaris
C'est la vie
For now Im going to stay with the same turbo. I am going to by some larger injectors and add a return line. Then I am going to buy the Ptuning turbo manafold that locates the turbo above the valve cover and a T3 style turbo with a external wastegate and a dump tube. I will also make a three inch exhaust.
Old 05-26-2012, 12:48 AM   #7
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
once you get all the specs worked out send them to Garm so we can persuade him into setting up and creating a kit
Old 05-25-2012, 10:37 PM   #8
beast!
Old 05-26-2012, 10:48 AM   #9
pimp my yaris
C'est la vie
something like this
Old 05-26-2012, 11:47 AM   #10
Golddeenoh
Golddeenoh's Avatar
what are you going to do about the cowl on the car to allow the turbo to fit with out melting the plastic?
Old 05-26-2012, 12:35 PM   #11
^ Dremel.
Old 05-26-2012, 06:25 PM   #12
Yoda
Yoda's Avatar
Wat about rain?
Old 05-26-2012, 06:32 PM   #13
Golddeenoh
Golddeenoh's Avatar
if it isn't a daily driver and is kept inside a garage it could just be removed and allow better ventilation of the engine bay add an under panel kit and then air would theoretically go in through the grill over the intake, and over the intake side turbo piping and then exit over the windshield. but leaving that opening will allow a lot of stuff to possibly fall into the engine bay and not having windshield wipers in the rain might be a problem but otherwise it could be an increased functionality of the system :D
Old 05-26-2012, 10:53 PM   #14
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I like this setup alot
-Derrick-
Old 05-27-2012, 11:42 AM   #15
Is this how blown_xA's turbo is set up?
Old 05-27-2012, 07:14 PM   #16
pimp my yaris
C'est la vie
Yes this is the same set up as blown XA
Old 05-27-2012, 07:23 PM   #17
pimp my yaris
C'est la vie
I am not able to start my car after reassembly. I am getting spark and fuel but I think the timing may be off I have tried swaping cam and crank sensors already. I have also double checked timing chain. I can see rpm on my scanner when cranking engine. Compression dry is 85-90 psi and 120 with a little oil. I know the rings have not seated yet. I am wondering if the crankshaft tone ring on a older 1nz may be differn't from my newer engine I took out. The part number for the sensor is the same.
If anyone has had similar problem after engine swap let me know? I bought a timing light and will try to check soon while cranking. It will sputter a little but will not start.
Any ideas welcome?
Old 05-27-2012, 08:24 PM   #18
Any ideas welcome?
Is the harness hooked back up completely, including the ground terminals that bolt to the block as some of those are the only ground for some of the sensors?
