Originally Posted by 07typeS
do you want the cut off that low? or is that ideal when you have your mid bass set up right and everything?
The lower the subs are cutoff, the better... so long as the midbass can keep up. With stronger midbass, I'd like to cutoff below 50hz, at that point the bass entirely feels like its coming from the front, at least to my ears.
Right now the deck xover is set to 60hz (as can be seen by the slow roloff) and the amp xover is set to 75/80hz... it shapes the xover well for my particular uses.
That being said, my midbass (stock - lol) can't keep up... its just that I prefer the sound of a low x'd over sub... this is another reason why I like the type R - it doesn't offer much beyond 50hz (as can be seen by the slight dip in the graph). I design to compensate as much as possible for the R's shortcomings, but it is what it is.
As I've experienced before, the 10" R exhibits a big fat impedence rise and is tough to get power to. I'll have some more test data (actual power, actual impedence) soon... along with a comparison to a sealed box, and a prefab ported box.
