Old 05-22-2012, 06:37 PM   #3
ggrieco
Drives: 2008 yaris aero
The fuse is OK as the fogs work when all is reconnected as it should be.
I will try to diconnect the blue wire fron the DRL relay, but this is not easy as the harness to the relay is on the short side. I will also try to ground the orange wire in conn. 13 pin 4 and i`ll let you know how things turn out.
Won`t be doing this real soon as I have spent enough time under the dash for one wk-end.
Thanks again....
ggrieco is offline   Reply With Quote
halos and DRLs KSIbucky General Yaris / Vitz Discussion 0 02-20-2012 08:06 AM
Suitable DRL's Nips Photo-Video-Media Gallery 1 08-16-2011 03:06 AM
DRLs and SRS guzziknight General Yaris / Vitz Discussion 8 06-07-2009 02:19 PM
DRL'S ARE SO ANOING KSIbucky DIY / Maintenance / Service 1 11-01-2006 06:59 PM
adding DRL's..?? static808 DIY / Maintenance / Service 9 10-20-2006 05:15 AM
