play every day
Micro Image center exhaust...
Today was a totally fun day because I got to visit Jeff at Micro Image to take a look at their really cool axle back center exit exhaust...
...and I went home with one. ![]() ![]() ![]() It's 2.25 pounds heavier than the stock exhaust. One reason is that the tubing is a lot larger. The muffler is a small oval 2 1/4 inch offset port Magna Flow Performance muffler. ![]() the ground clearance is superb as the whole exhaust tucks so nicely up inside the car without anything hanging down, and without anything touching anything else that it shouldnt touch. ![]() I sprayed the whole thing BBQ black (a personal favorite ) so that none of the exhaust would show up except just the edges of the stainless steel twin tips.![]() I really like the simple unobtrusive look with as little of the exhaust visible as possible. ![]() ![]() It utilizes the stock spring bolts and comes with matching nuts as the stock nuts are flash welded onto the flange that was removed along with the original exhaust. ![]() The flat oval muffler fits well and lays parallel to the ground. ![]() ![]() It has an understated look which I find very appealing. The exhaust uses the two original rubber donuts and lines up perfectly with them when the spring bolts are snugged down. The third mount on the twin tip is a self tapping screw with a small angled bracket that you attach to the crash bar behind the bumper. I just used a little piece of wire to attach the third donut to that angle bracket as there's very little room to work there. It hardly needs to support any weight, because almost all the weight is on the two stock donuts. It's just used to slightly adjust the height of the tip. ![]() ![]() ...and it sounds even better than it looks. ![]() It's basically silent at idle and you couldn't tell it from the sound of the stock exhaust. Running it has a rich mellow tone with absolutely no raspy ricey overtones. On deceleration it has a pleasant burble like a small European 60's sports car. You really hear it when you step on the gas, but even then it still retains its rich deep warm tone with no other extraneous irritating noises. In my opinion, this was a very well thought out product design. My thanks to Garm and Jeff for producing a really fine and unique product that no one else makes. Last edited by tooter; 06-07-2012 at 12:28 AM. |
whoa, double post! :D
play every day
Hey Garm... what happened???
![]() I was responding to your post and a message came up "invalid link notify administrator"... then my post disappeared. Again. If there were any notable negatives to your exhaust, I'd certainly say so. By the way, I resolved the stainless question simply by looking it up on the internet. Your exhaust is all stainless with the only exception being the small concave two bolt hole bracket which accepts the stock donut gasket. It had surface rust on it, but nowhere else was there even a trace of rust including the welds. The Magnaflow mufflers are listed as either "polished stainless", or "natural stainless" (unpolished). None of them are listed as steel. When chromium and carbon are added to iron, they make it strong and stainless which is typical of cutlery... and they also make it magnetic. (I personally verified this by determining that all of our stainless kitchen knives stick like crazy to a magnet... and none of them rust. ) The highly polished twin tip is nickel stainless, because when nickel is added the alloy becomes non magnetic.... but it's also softer. I believe the softer less structurally critical nickel alloy sheet metal is easier to form into the intricate contours of the tip. Last edited by tooter; 06-07-2012 at 01:07 AM. |
play every day
#5 | |
play every day
It's ok... I saw your original post before it disappeared.
![]() And thanks for the nuts! ![]() They worked perfectly. Now the original bolts can bottom to their flanges and compress the springs just right. It's amazing how well the exhaust reoriented itself with the spring bolts snugged down properly. There is almost no weight on the third non stock point of attachment at the tip which is good. I haven't yet figured out how to attach it because space is really tight up in there. If the donut is attached to the angle bracket first, the self threading nut can't be accessed to tighten it to the lip of the crash bar. So I just used a piece of wire to connect the donut to the angle bracket and tightened the wire to get the height just right. Since there is almost no tension on it at all I'll probably just keep it that way. Your exhaust sounds so nice even my wife likes it. ... and that says a lot.
should have picked up some lowering springs! ;)
play every day
Oh there were plenty of them there as well as really cool coilovers. But I live in a rural area with some dirt roads and prone to winter flooding. Ground clearance has practical value here so I won't be giving it up. That's what I like about the MI exhaust. it Doesn't compormise ground clearance one little bit.
Pirate Yaaaaris
Drives: '00 Toyota Celica GTS 6MT Join Date: Aug 2009
Tooter, is there a way you can get a sound clip of this? I've been eyeballing it hard since it is readymade instead of going forward with my own center exit exhaust. Looks great although I'll probably leave mine polished if I order one.
-C
Georgia Bulldogs! ![]() '09 Yaris LB 5MT Sold. |
play every day
Be happy to...
![]() My wife took the car to town today and I'm working tomorrow, so maybe on Saturday if there isn't time later today. Garm also took a sound clip when I was there, so it may turn up on his website later on. A muffler shop would have a difficult time beating the superb fit. And that's the distinct advantage of a complete ready made assembly, the engineering has already been built into it. Jeff showed me the original prototype when I was there. |
play every day
Here's a link to the YouTube sound clip:
http://www.youtube.com/watch?v=nQjo6...ature=youtu.be I put the microphone really close as the sound is pretty mild from a distance. |
All black everything.
Drives: '09 5dr All black. Join Date: Dec 2011
OH MY GOD! I am NOT that into exhausts, but that sounds AMAZING! It is like a lion!
Which Magnaflow muffler is that? AND does the fact that you have different headers change the sound? Thanks for a great thread AND the audio! |
I love it!
#14 | ||||
play every day
![]() Quote:
![]() It's an offset port muffler which makes the sound more mellow than a straight through. Quote:
Pirate Yaaaaris
I'm sold. It being center exit AND being from a trusted source. Now to come up with...gulp...$449.
-C
play every day
Yes, it gets pretty loud when you step on the gas... but it's not obnoxious, edgy, raspy or tinny. In normal driving it's quite mellow. In running, the sound is exactly like what you heard except louder because there's a load on the engine. In the video I only revved it to 4,000rpm.
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2012
Man, really wished this could come out for the sedan
play every day
Is the difference just the body length, or are there other structural differences in the chassis itself?
| Micro Image lowering springs 1.8" drop | markylicious | Middle East | 144 | 10-30-2011 01:18 AM |
| Micro Image Short Shift Kit- prototype review | mazilla | Performance Modifications | 124 | 09-26-2011 06:04 PM |
| Enkei's and Dunlops + Medalion Touring Exhaust | 2manywheels | Items for Sale by private party | 40 | 04-04-2011 05:01 PM |
| Micro Image meet Jan 30, 2010 | Brian | Photo-Video-Media Gallery | 57 | 02-06-2010 10:27 PM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
