Old 07-19-2012, 02:44 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Originally Posted by Jason@SportsCar View Post
You want to add weight to move weight? Waste of time. Put a 6lb battery in the stock location and call it a day.
It's not quite adding weight since the wire only weighs 3 lbs and my battery currently weighs 27. The braille is on my list of improvements I just don't like having weight up high, hell I'd move the battery where most of the CAI's pull in just to get the weight lower on the car. But I'm sure that 6lbs up top make almost no difference.
I've found the LSD isn't such an issue if you get rid of the front bar but figuring out the spring rates you need to run to compensate for no front bar is another matter all together.
I think the Yaris would be way more fun in FSP than in STFail. LSD, light flywheel, big wheels and tires (wide and short), power.
I believe its STFu
Old 07-19-2012, 02:51 PM   #2
Jason@SportsCar
Sorry, 30lbs in the back is not an improvement over 6lbs in the front. Also don't forget the mounting hardware and battery box if you are using a non-sealed battery. But it will be worth it for the added inconvenience of having the battery using up hatch space.
Go look at fast ST Hondas, you will find the battery under the hood. But go ahead and reinvent the wheel.
Time Waste Wednesday: Three new posts on Subcompact Culture Thirty-Nine Off-topic / Other Cars / Everything else Discussions 0 04-29-2009 11:23 PM
How many posts till ChinoCharles locks this thread? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 9 04-14-2009 05:54 AM
Reported posts ChinoCharles Suggestions - Feedback - Questions 10 09-25-2007 07:48 AM
