Old 09-04-2012, 04:29 PM   #1
matti
Drives: 2017 Yaris L (5sp manual)
Doing pretty well. If you want more, I think you're only options (for driving technique) would be kicking in DFCO much sooner than you already are or using FAS.
Thanks. What is FAS?
matti is offline   Reply With Quote
Old 09-04-2012, 04:55 PM   #2
iirc, FAS = forced auto stop. Essentially turning off the engine (put the ignition back on "ON" to make sure you still have the ability to turn and brake). It's a little more advanced. If the stop light has turned red way ahead of you, you can use FAS so you're not slowing down as much as you would with DFCO. You can come to a stop and still have the engine off, thus not wasting gas by idling. NOTE: you will only have the ability to have two or three good pumps on the brakes, so use it wisely. If you came to a stop, start the engine again, if not, bump start the engine in 5th. You can also use FAS if you're going down a hill to either keep momentum or gain some speed. FAS uses no gas at all vs the very, very minute amount of gas that DFCO uses.
Old 09-04-2012, 04:57 PM   #3
matti
Thanks. I now know that FAS is definitely not for me! Interesting, though.
Old 09-04-2012, 04:58 PM   #4
If you know that the stop light is a long one, you can always shut off the engine when you've come to a stop.
Old 09-04-2012, 06:09 PM   #5
nookandcrannycar
If I remember correctly, dollar wise, restarting = 30 seconds of idling. So 31 second + stops with the engine off save money.
Old 09-04-2012, 07:01 PM   #6
Brian told me it was like 7-8 seconds. No clue. I only turn off my engine if I know I'll be at a light for at least a minute. LOL
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 01:15 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 12:49 PM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
New personal record: 53.69 MPG BailOut Fuel Economy Forum 26 08-21-2009 07:31 PM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 06:48 PM
