Old 09-04-2012, 06:48 PM   #1
white_rice
white_rice's Avatar
Drives: 2008 Toyota Yaris LE
Send a message via MSN to white_rice
Originally Posted by Viperoni View Post
Neither, I've never noticed a performance or mileage difference over Laser Iridium's, Bosch Platinum +4 IR's, Platinum +4's or regular NGK V-groove copper plugs.
So I just run v-groove plugs all the time now and change them every 10-20k kms.
Thanks for the heads up. I will have to make a decision. You change your spark plugs that often though eh? I was thinking every 100,000KM would be sufficient enough?
white_rice is offline   Reply With Quote
Old 09-05-2012, 11:42 PM   #2
Viperoni
Drives: 2005 Toyota Echo
I should have added that I race the car as well.
Apparently copper plugs only last around 30k kms (just did some googling), but they conduct electricity better.
With them being so cheap, the moment you notice a decrease in mileage is a good sign it's time for them to go, and considering how easy ours are to change, it should be a no-brainer.
2006 Saturn Ion Redline
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 10:44 AM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 05:46 PM
Where do I buy ngk iridium tip 7 heat spark plugs? PETERPOOP Performance Modifications 23 03-08-2009 09:34 PM
FS: OEM NGK Spark Plugs mikenacarato Items for Sale by private party 13 01-23-2009 05:05 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
