Old 09-09-2012, 11:01 AM   #1
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
Yaris to Vitz conversion
Does anyone have a source for all of the required parts?
I know MI has the badges! But I would also want the floor mats embroidered with Vitz as well as aluminum door sill protectors(I currently have the ones that say Yaris).
Anything else I'm missing?
Captain Slow is offline   Reply With Quote
Old 09-09-2012, 02:24 PM   #2
MadMax
MadMax's Avatar
Just note that the Vitz doesn't not have a Netz emblem on the rear, only the front. I just spent a week in Tokyo and picked up a OEM Netz badge for the front of my Yaris. Also, the Vitz emblem on the rear goes on the left side where the 'Toyota' emblem resides on the Yaris. There is no emblem on the right side.
Also, the Vitz does not have the side marker lights as the Yaris does.
I've got a bunch of pics if you need references...
Cheers! M2
Old 09-10-2012, 12:09 PM   #3
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Cheers! M2
Please post the pics. I'd like to see them.
Old 09-10-2012, 12:29 PM   #4
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
+1
Old 09-23-2012, 03:19 PM   #5
MadMax
MadMax's Avatar
Here ya go, these are some of the 47 pics I took during my week in western Tokyo (Fussa)...
Note that some do have side marker lights, but others don't. I just realized that, but at least that means Captain Slow wouldn't have to remove his to be "authentic" since as far as I can tell, the earlier models (2008 and prior) don't have 'em whereas from 2009 onward they do.
But also note that the Vitz only has the Netz emblem on front, and the Toyota one on the rear. Also, the 'Vitz' badge is on the left whereas our 'Yaris' one is on the right; and there is no written 'Toyota' badge as on the US versions.
Hope that helps!
Cheers! M2
Old 12-03-2012, 05:53 PM   #6
jcboy
Drives: Sedan 07
Hope that helps!
Cheers! M2
Actually if you have sidemarkers, you wouldnt have led sidemirrors, and vice versa. it's similar to the ones here in manila, except for the RHD.
so yes, captain doesnt have to eliminate his sidemarkers at all, unless he has LED sidemirror covers, which IMO are easy to replace with non-led covers anyway.
Old 12-03-2012, 06:06 PM   #7
MadMax
MadMax's Avatar
That tracks, hadn't noticed it but now that you've told us, it makes sense!
We don't have the LED side mirror covers here in the States, unless someone imported them.
Cheers! M2
Old 09-10-2012, 12:54 PM   #8
Captain Slow
hmm, on second thought I will definitely not be doing the conversion. I'm really anal about details and the fact that I could not eliminate the side markers and that the car is LHD instead of RHD means it would never be a true conversion.
oh well. was just a thought anyway.
Old 09-10-2012, 01:04 PM   #9
suckerface
#1 Lemming
suckerface's Avatar
You could do the side markers, I'm pretty sure other people have. It's just a matter of getting them filled in with bondo, and blending/painting it in to match. Granted, it won't be easy...
The only part that'd be next to impossible is, as you mentioned, the LHD v RHD aspect. There was another user who was doing a GREAT job on a Vitz conversion, unfortunately, that car is gone, and all the pics have been pulled.
Old 09-10-2012, 02:11 PM   #10
Captain's biggest obstacle for a true Vitz conversion; number of doors.
Vitz only comes in 5dr. Captain has two less doors.
Old 09-22-2012, 05:54 PM   #11
Astroman
Modded Moderator
Astroman's Avatar
That indeed is the biggest problem.
Please try to post your threads in the correct thread section. It's getting old moving all the stuff from the "general discussion" when this was DIY related. I've moved it to the proper sections
Old 09-23-2012, 08:01 PM   #12
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
does that silver one really have an AWD decal on it, too bad we can't get that State Side.
Old 09-23-2012, 08:53 PM   #13
MadMax
MadMax's Avatar
Yep, I saw another one at Narita Airport...
Cheers! M2
Old 07-02-2013, 09:53 PM   #14
MUSKOKA800
MUSKOKA800's Avatar
Cheers! M2
Holy off-road set-up. Could they get any more fender gap? That's hideous!
Old 07-02-2013, 10:14 PM   #15
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I think those may be 14" or even 13" wheels. Looks terribly unstable at parking lot speeds!
Old 09-23-2012, 08:59 PM   #16
^ you should have hunkered down beside it and looked to see if that second axle mount location people have been using is actually for the purposes of accomodating AWD. It's been speculated that that is the reason for it's existance.
Old 11-21-2012, 06:34 PM   #17
Fidelio
EcoFriendly
Fidelio's Avatar
Drives: 2007 Vitz HB
I just received my emblems in the mail from microimage.
Fidelio is offline   Reply With Quote
Old 11-22-2012, 12:58 AM   #18
There's a lot more to a true RS than just badges... different seats and interior fabric, electronic climate control, etc etc... And yes, 5 doors and the steering wheel on the other side!
JDM Yaris Vitz emblems? Y@R15 Cosmetic Modifications (Exterior/Interior) 4 08-24-2010 11:03 AM
Tail Lights Yaris Vitz 1999-2001 bieniman Cosmetic Modifications (Exterior/Interior) 4 12-09-2008 10:50 AM
