Form>Function
I ran ksport springs on my sedan for a while and they had about as much of a drop as the teins give or take a few mm. The handling was great and it was a progressive rate spring so under little to no compression the ride was nice. When you need stiffness it was there. Never bottomed her out with those unless going over big speed bumps too quickly. Springs by themselves will give you a decent drop and some stiffness without being expensive and like you said you can do the struts at a later date, although that gives you double the work.
I now have Megan coilovers which I love. The adjustability of ride height and stiffness is awesome and you can dial your car in to the exact settings you desire. The drop and dampening can be a lot higher than springs or a lot lower depending how you set it. But those are pretty expensive, a little easier than springs to install though. btw my ksport springs only ran about $100 shipped. |
![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
I just want to get rid of that horrific factory wheel gap, but not have enough left to be able to say something like:
"Yeah, its lowered... but it still looks like it should have gone down just a bit more..." I hate when that happens. |
#3 | |
![]() ![]() ![]() Drives: Toyota Belta Join Date: May 2011
Form>Function
Yea that's why I upgraded to coilovers
The OP is asking for a medium drop, 1.5" to 1.75" if I read it correctly. S Techs drop 2" or very close to it.
I would recommend the Sportlines, our MI springs or H&R. H&R have such a nice ride, being a progressive spring that gets stiffer when you corner hard.
#6 | ||
Got a link to the exact Megan combo setup you're running? That sounds like the right way to go for me. I'm seldom satisfied with the ride height after lowering a car. So maybe I'll just save up and get those. That way I can adjust the ride height to be what I want. Quote:
Form>Function
I gave three choices, and you said "they" ride kinda rough. which ones did you mean?
The H&R or Sportlines are going to be a nice, firm ride. The Tanabe DF210 springs will give you a FACTORY ride while lowering the car.
#9 | |
Toyota
Drives: '11 5dr/5spd yaris Join Date: Nov 2009
When you say factory ride you mean in terms of comfort, correct? Not handling/performance? What would you pair with the DF210 springs to maintain that factory ride? |
Sorry I meant the Tien S-techs. I believe it was 1.5 who said that they don't ride anything like the factory ride quality. I'm looking to go as low as I can possibly go, while still keeping factory ride quality. Something tells me that's about 1.5 inches max.
no show, no go :(
i just dropped my car on s-techs 2 weeks ago, and on stock shocks, mine rides completely like stock.
#12 | |
Form>Function
That was kaotic who said that. I never rode on s techs.
You said you want 1.5-1.75 no less but then you said you want almost no wheel gap and that you don't want to drop it and then think it's not enough. This all makes it sound like you may want more of a drop than you thought. For the lowest spring drop its going to be s techs with a few others coming in close second like ksports and MI. The ride will be considerably stiffer. I can say the ksports actually retain a very smooth cushy ride for having a more a aggressive drop. The shorter drops should be closer to stock feel but will give you very minimal ride height change. And again there are coilovers. |
Form>Function
I doubt that ^
no show, no go :(
why would i lie about something like that? then again, i've heard the gen3s ride stiffer than gen2s...
![]() ![]() ![]() Drives: 09 Blizzard Pearl RS LB Join Date: Sep 2009
no show, no go :(
i cut off half of my bump stops - about 1.5 to 2 inches - makes up for the reduced height.
But yeah, keep in mind that I'm on TRD Sportivo dampers, 205/40/17 tires on max psi, and I do have spring coil spacers in the rear.
| Dash Kit - No Mods | barryware | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 09-14-2014 03:59 PM |
| what to look out for when installing lowering springs | songa | Performance Modifications | 34 | 09-15-2012 03:29 AM |
| I need a body kit | LA Yaris | California | 1 | 11-06-2009 01:26 AM |
| Is aftermarket HID kit legal (in NJ)? | Jfoofoo | Cosmetic Modifications (Exterior/Interior) | 25 | 03-19-2009 02:05 PM |
| Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? | ceboyd | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-08-2006 02:13 PM |
