Old 09-18-2012, 02:21 PM   #1
Originally Posted by Tomatogrower View Post
Oh ok, thank you! What would your suggestion be to best route the white wire (brown clip) to the battery? Is there a wire already under the dash which I could tap or splice into? Thanks!
Look in the DIY section of the forum for my Remote Starter DIY for info on where to grab constant or ignition switched power right under the dash.
Old 09-18-2012, 02:28 PM   #2
Tomatogrower
The Flying Tomato
Tomatogrower's Avatar
Drives: 2009 Red Yaris Hatchback
Excellent, thank you very much! You've been a big help I'll let you know how it turns out!
Tomatogrower is offline   Reply With Quote
Old 09-19-2012, 04:08 PM   #3
Tomatogrower
The Flying Tomato
Sorry, I am a little new to this...where can I find the parking light wire under the dash? Thanks!
Old 09-19-2012, 04:15 PM   #4
Tomatogrower
The Flying Tomato
I apologize, I just found it:
http://www.modifiedlife.com/2009-toy...-instructions/
Pin 29, correct? (Green wire)
Old 09-19-2012, 09:17 PM   #5
Actually this thread is what I was pointing you to:
http://www.yarisworld.com/forums/sho...y+remote+start
My documentation shows pictures of the locations.
If you are thinking of having them come on with your parking lights, then you will want to modify the harness per the Micro Image DIY. The way that the included harness is designed, you would connect the kit to ground and battery power (or to have it ignition switched you would use an extra relay connected to the ignition switched power wire per my DIY and would switch the battery power using that second relay).
Old 09-20-2012, 02:18 AM   #6
Tomatogrower
The Flying Tomato
Thank you! The way I wired it this afternoon was:
-I connected the foglight power wire (white with brown clip) to the constant 12V source
-I connected the switch illumination wire (red with white clip) to the parking lights.
This configuration worked fine temporarily; the switch illuminated when the parking lights were on and the fog lights turned on when the switch was activated.
However, when I put the plastic casings back into place, the parking lights had issues. They will not turn on, which in turn doesn't illuminate/power the switch, so the fog lights won't activate.
Any thoughts? Does grounding at different grounding points affect anything? I checked the fuse, and it was still good. It seems like there may be an issue with the grounding or my tap splice with the parking lights...
Thanks, you've been a big help! I greatly appreciate your patience with this!
Old 09-20-2012, 04:06 AM   #7
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
If everything worked fine before you put the bezel and lights back in,
then most likely you accidentally pulled or pinched a wire or connection somewhere.
You'll have to retrace your wires. Ground should be a solid ground - to the frame/body of the car would be ideal.
Old 09-20-2012, 06:42 AM   #8
Check the TAIL fuse in the fuse panel under the bottom of the dash. I have a feeling that the red wire was actually the power wire, so you were pulling the power for the fogs from it.
Old 09-20-2012, 09:19 AM   #9
Tomatogrower
The Flying Tomato
Hm...I didn't think about the pinched wires...I will check! I attached the ground to the ground location just under the steering wheel. I will see if I can attach it to the frame. I find it odd that it would be from a pinched wire though, considering the parking lights don't work; any wire I can see getting pinched would be for fog light wiring.
I checked the Tail fuse last night, and it was ok. I was hoping that was the issue lol, but unfortunately not.
I'm sure the red wire was to power the illumination switch; I was testing the connection throughout the installation, and when I wired the red wire to the parking lights prior to wiring the white wire with the 12v connection, the switch would illuminate without powering the fog lights. So that seemed as a check that it was wired to the correct points.
Old 09-20-2012, 09:30 AM   #10
I would double check the TAIL fuse, as only that and the 120A ALT fuse are in circuit with the tails. Since they worked for a bit and then went out, the fuse may have opened less catastrophically than if it blew due to a short.
The only other thing that may have gotten damaged is the T-LP relay, but that it integrated into the internals of the body ECU, so to replace it you would have to replace the entire under dash fuse panel assembly.
Tags
diy, fog lights, installation, wires
Fog light jumping question netz2008 DIY / Maintenance / Service 1 01-16-2012 09:55 PM
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
question on Fog light clfile Cosmetic Modifications (Exterior/Interior) 6 11-09-2006 07:11 PM
rear fog light and tuned rear lights lefti696 Cosmetic Modifications (Exterior/Interior) 0 11-09-2006 03:06 PM
