#1 | |
![]() ![]() ![]() Drives: Miss my Yaris, love my Jeep jk Join Date: Aug 2011
Quote: Originally Posted by Sirius-XM The Yaris has a torsion beam suspension so the sway bar isn't really a sway bar in the conventional sense but is instead a reinforcing spring for the torsion beam. It attaches to trailing arm part of torsion Beam. If this is the TRD Sway Bar for the Yaris (PTR11-52071), the installation instructions over at TRD Sparks where I got mine. A sway bar is indeed a torsion spring, but the rear suspension on the Yaris isn't a torsion bar set-up, as Sirius-XM says it is. It isn't. The sway bar isnt "a reinforcing spring spring for the torsion beam", as he states. It's a torsion spring to be installed (in the case of the Yaris) on a coil-sprung solid type rear axle. Same net effect, but not acting on a torsion bar type of axle.
I'm the Prez at my house...in fact I cruise around in YarForce One! When I'm not driving my Yaris, I'm doing this: http://gogogordy1.wix.com/scooter-aficionado |
#2 | |
Quote: Originally Posted by Sirius-XM The Yaris has a torsion beam suspension so the sway bar isn't really a sway bar in the conventional sense but is instead a reinforcing spring for the torsion beam. It attaches to trailing arm part of torsion Beam. If this is the TRD Sway Bar for the Yaris (PTR11-52071), the installation instructions over at TRD Sparks where I got mine. A sway bar is indeed a torsion spring, but the rear suspension on the Yaris isn't a torsion bar set-up, as Sirius-XM says it is. It isn't. The sway bar isnt "a reinforcing spring spring for the torsion beam", as he states. It's a torsion spring to be installed (in the case of the Yaris) on a coil-sprung solid type rear axle. Same net effect, to minimize roll but not acting on a torsion bar type of axle in this case. http://en.wikipedia.org/wiki/Torsion_bar_suspension
Glad we got that all straightened out!
We're both quite relieved, I'm sure!
Toyota (TM) Shareholder
I said the suspension is a torsion BEAM not Torsion Bar.
http://en.wikipedia.org/wiki/Torsion_beam It is a torsion beam as opposed to two independent swing arms that can be attached in a variety of manners. Using the Beetle as an example, The Beetle had two independent trailing arms that attached to the body via torsion bars in a tube. The yaris has a single unit suspension with a beam that twists to allow the trailing arms some degree of independence. |
#6 | |
| xA or xD front sway bar fit in to 07 Yaris | yariseggvvti | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 10-29-2012 09:47 PM |
