![]() Drives: 2008 yaris 1.4 Join Date: Jul 2012
I have my psi at about 46 and the car drives straight as an arrow,
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
hmmmm, I would have your brakes checked. They might be producing too much friction, causing your engine to work harder to get the car to speed and to maintain speed. If your tire pressure is high and your alignment is within manufacturer specs, you really shouldn't be having mpg issues.
So have your brakes checked, change your spark plugs, and change your intake air filter. Also, if you are using cheapo gas, I'd suggest switching to a top tier station. |
I have gotten new spark plugs, what you you guys prefer ?
![]() ![]() Drives: red Liftback Join Date: Aug 2007
Popular Mechanics had an article about tire pressure and mpg. The manufacturers recommended pressure is designed to put the least wear on the suspension. Significantly higher tire pressure will increase your mileage (less road friction) but will greatly increase suspension wear. So with higher pressure you get better mileage and lower fuel costs but higher repair bills later on.
![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
it is possible... translate into km that is 350km. On my yaris, i fit it with mini cooper 17" wheels(heavy) and now i've lost 30km on a full tank.
I drive 50/50 city and highway, and I am only getting 430km, then the fuel light flashes, about 9.4L/100km. so basically if I were doing 90-100% city, it is not surprising to get 350km(218 miles) if you do the math, or just google look it up my numbers translate back to your mpg or miles, you will get an idea. my car is completely stock under the hood. |
well i find it odd because looking at the mpg people are getting in the forums, a lot of them are getting Lazy 30mpg all city driving
Yeah, city driving, I'm driving 17 miles to work in one rather large city. Not three miles, and letting it idle for two minutes. I'm surprised you're even getting 21 mpg.
#9 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Wheel Diameter Almost everyone here runs different diameter rims combined with a wide variety of different sized tires... ...and yet no one seems to be factoring in their wheel diameters to adjust their odometer readings to arrive at their actual gas mileage. I changed my rims and tires just like everyone else, except I used a wheel diameter chart to determine the tire size and aspect ratio so as to keep the diameter within 1% of the stock diameter so that my odometer continues to give accurate readings.
I wonder if by city driving people are in the city on the highway long trips at high speeds, when i say 100% city driving i mean stop lights often
#11 | |
play every day
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Something aint right try some of the obvious fixes then i'd say it would be worth your while to take it to a reputable garage and get it fixed..
http://www.carsdirect.com/car-buying...ad-gas-mileage
Have Yaris will travel.. |
#13 | |
Ever since I changed to 17' Cooper S rims, my speedo is slower than actual speed. Therefore the distance counter must be also slower (less), that would make sense to the loss mileage! |
#14 |
DAT'S RIGHT I GOTz 2
OP did you change your oil lately?
#15 |
yes i did, 5w 30 royal purple
#16 |
![]() Drives: 07 Sedan S Join Date: Dec 2012
Original Intake gets you better gas milage. Try it
#17 |
Also check alignment
#18 |
![]() ![]() ![]() ![]() ![]() Drives: 09 Yaris HB, 08 SR5 Tundra Join Date: Jan 2009
My mileage has never been all that great either. But I think the city of Odessa (since it's an oil town) actually constructs everything in such a way that people use as much gasoline as possible. Ok maybe that's a stretch but seriously the civil engineers around here must be bottom of the barrel because the traffic here is a nightmare and shouldn't be for a town of this population. Maybe you are in a town that doesn't have anything set up very well either. Just try driving a Tundra that gets 12mpg around for a while and then you'll love your 21mpg.
Like seriously if there is an intersection in this town without a stoplight i'm sure they are working on putting one up right this very moment. And god forbid you ever make more than one green.
![]() I crush you like tiny clown car, because you are clown, yes? |
| Tags |
| gas, mpg |
| Save thousands and BIG MPG almost PRIUS | jay cobbs | New YARIS Purchase Forum | 6 | 08-28-2012 08:38 PM |
| Why sub-compacts and compacts get almost the same MPG | Kal-El | Off-topic / Other Cars / Everything else Discussions | 0 | 08-10-2011 11:51 PM |
| 3000 mi Summer Trip Log...MPG included! | slothman86 | Fuel Economy Forum | 14 | 07-20-2010 12:15 PM |
| Better MPG in the City vs. Hwy | Loren | Fuel Economy Forum | 21 | 01-29-2010 11:49 AM |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
